Old 04-01-2006, 11:11 PM   #1
matthufham
constant power fuse
is there one on the fuse block? i need power with key on acc, off, and run for my radio to keep the memory (clock and pre-sets).
or should i run a wire to the battery with a 20 amp inline fuse?
matthufham is offline   Reply With Quote
Old 04-02-2006, 01:02 AM   #2
Karl Hoh
A little east of nowhere
Re: constant power fuse
I don't think these trucks had a takeoff in the fuse box for constant power. The only power out with the key in the acc/off/run positions is lights, cig lighter & 4way flasher? Why not tee in to the cig lighter power?
68 C10 250 4spd
69 C20 327 4spd
69 910 250 3spd
80 K10 350 4spd
76 C60 366 5spd school bus
"THERE'S NOTHING YOU CAN BREAK THAT SOMEONE CAN'T BE PAID TO REPAIR"
Karl Hoh is offline   Reply With Quote
Old 04-02-2006, 01:05 AM   #3
dwaite72lnghrn
I pretty sure the cigar lighter tap on the fuse block is hot all times. the other point would be at the top of the block just below the fuel gauge tap, it should have a pigtail connected to it.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 04-02-2006, 01:35 PM   #4
matthufham
hmm, you guys were right, the cigarette lighter and the plug under the fuel gauge have constant power. thanks i got it all figured out now.
Old 04-02-2006, 08:14 PM   #5
Bob Moore
Matt - Does that stay hot during crank? It MAY shut off during the starter cranking mode. Just check before you go too far.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 04-02-2006, 10:48 PM   #6
matthufham
no sir i will not be checking that soon. i don't want to kill the engine, never been fired. it has no oil pressure, just sitting there all pretty until the truck gets painted, also no gas tank until then. i guess i could disconnect the starter, but it's tricky and i'll leave it for now.
