Old 04-02-2006, 04:54 PM   #1
Wild83C10
Wild83C10's Avatar
DJM 3" Lower Control Arms
Soon I will be lowering my truck more then it currently is. I purchased a set of DJM lower control arms and I am thinking they may sit very close to the ground. I currently have 2" lowering spindles and I cut my springs about an inch. Any one have them installed? Any issues with ground clearance? Any pictures? Thanks
Joe
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 04-03-2006, 07:04 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: DJM 3" Lower Control Arms
Are you going to be using the spindles AND the LCA's together? I woudn't recommend that.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 04-03-2006, 07:20 PM   #3
Wild83C10
Wild83C10's Avatar
I was planning on it. What problems would I run into? I am looking for about a 5 inch drop in the front. What would be the best combo for that?
turbo=
Old 04-03-2006, 07:25 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
I did the same thing and the A arms drag the ground. You would have to run 20's on the front to keep it from dragging.
dwcsr is offline   Reply With Quote
Old 04-03-2006, 07:51 PM   #5
Wild83C10
Wild83C10's Avatar
So dwcsr, you have lowering lower control arms and drop spindles and that resulted in ground clearance issues? I am running 17s and I don't really want to go any bigger than that.
turbo=
Old 04-03-2006, 09:38 PM   #6
Wild83C10
Wild83C10's Avatar
Well I did some more research and it appears that if I want to lower my truck 5 " in the front and use the 3" lower control arms I should use the stock spindles with some lowering springs. That is what DJM has as one of there kits. Thanks for the heads up.
turbo=
Old 04-03-2006, 11:25 PM   #7
Captkaos
Captkaos's Avatar
Using those components together violates Scrub. Another words, you get a flat and you loose control since the control arms hang below the rim.
Spindles and LCA's are not designed to be used together. You need a 3" drop spring, or 3" spindles and 2" springs.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 04-04-2006, 01:57 AM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
I got the 2.5 drop spindles and the 3" drop A arms on 15" 29.5 tall tire and the A arms were about a 1/2" off the ground in the garage.
Old 04-04-2006, 01:59 AM   #9
dwcsr
Hollister Road Co.
dwcsr's Avatar
I'd have to agree. But must admit I have no idea what a scrub violation is.
Old 04-04-2006, 02:20 AM   #10
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Basically, a violation is when any frame or suspension part hangs lower than the scrub line of a vehicle. The scrub line is defined as lower part of the rim (i.e. if a vehicle was to rest on its' rims (without tires), no part of the suspension or frame should contact the ground.) It's good practice to set your suspension maintain the scrub line.
Like Chris said, using both dropped spindles and dropped arms are not recommended. (I don't even think 20s couldn't give you enough of a scrub line with the dropped spindle/arm combo.)
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 04-05-2006, 05:38 PM   #11
chevyfan420
not trying to hijak, but would just the 3" LCA be ok with 15's?
80 Chevy K10 350/350turbo
86 Chevy 1/2 ton shorty project truck
79 Chevy 1/2ton 350/350turbo
not much to look at... ***Retired***
97 Chevy C1500 4.3/5 speed.....daily driver
chevyfan420 is offline   Reply With Quote
Old 04-05-2006, 06:00 PM   #12
Captkaos
Captkaos's Avatar
Thank you sir! Excellent description. I guess I was a little vague...
It would be fine.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
