Old 04-02-2006, 06:53 PM   #1
kevncar
Active Member
kevncar's Avatar
junkyard tilt column
OK, I went to the junkyard today and got a 3-1/2 turn power steering box off a mid-70s chevy pickup and this tilt column. The only thing I'm worried about is I don't see the intermediate shaft everybody is talking about having to collapse.
Please...someone tell me I didn't get the wrong column. Am I supposed to collapse the shaft from my truck? (manual shift manual steering)
Or is the shaft inside the column and you have to remove it first, and then collapse?
There were a bunch of vans with tilts at both yards I went to, but most of them were the later models with the ignition on the column. This was the only tilt I found without the ignition. There were a bunch with non-tilts, and all of the columns shafts at the end looked about the same. They stuck out of the end of the column about 6". Nothing like the long shaft in my truck.
Please help
Kevin
72 Chevelle
67 C10...454/TH400
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961
kevncar is offline   Reply With Quote
Old 04-02-2006, 07:20 PM   #2
71swb4x4
71swb4x4's Avatar
Re: junkyard tilt column
The intermediate shaft is the one hanging off your current column. It's in the bottom picture.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-02-2006, 07:58 PM   #3
Bob Moore
Kevncar - The column in your truck now is the 67 one piece shaft style. IIR in 68 but definetly by 69 GM went to a 2 piece shaft. The intermediate is about 18 inches long. The steering box end has the wavy flange to bolt to the rag joint. The firewall end has through bolt connecter to the shaft.
The intermediate shaft has to be from 69-72 to have the correct shaft diameter. 73 P/U uses a 1 inch shaft while the 67-72 has 3/4inch shaft. Once you get the intermediate shaft it needs to be collapse about 2 1/2 inches.
The intermediate shaft is used on all 69-72 PU - non-tilt,tilt, and manual - 2wd and 4 wd - PU, Blazer and Suburban.
Keep searching - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 04-02-2006, 08:02 PM   #4
john
member #16
john's Avatar
There is a complete how to in the FAQ. What you have will work with a couple of mods. John
john is offline   Reply With Quote
Old 04-02-2006, 08:39 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You're going to remove the pinch bolt and then remove the coupler deal off the end of the new column.
Then, get a intermediate shaft off any 69-72 truck and shorten it. It will then install onto your stub shaft sticking out of the column.
Old 04-02-2006, 11:22 PM   #6
kevncar
Active Member
kevncar's Avatar
the shaft in my 67 is a two piece. I can see the little plastic pins the FAQs say to drill out before colapsing. I've read the FAQ's several times, I just never got that the shaft comes from or with the truck. I always thought the shaft would be on the van column. Glad to hear the column is what I need. Unless somebody chimes in the tells me why the shaft on my 67 won't work, I'll just try it and if not then I'll go back to the yard for the shaft from a 69-72.
thanks guys
Kevin
72 Chevelle
67 C10...454/TH400
Old 04-02-2006, 11:57 PM   #7
pjmoreland
pjmoreland's Avatar
Your '67 column has two sections that are connected together by those plastic pins. The upper section runs all the way up to the steering wheel. The '69-72 columns have three sections, and a pivot with a rubber boot on it. Note that yours does not have the pivot. You can see the two lower sections in this picture. You definitely need to take a trip back to the wrecking yard.
pjmoreland is offline   Reply With Quote
Old 04-03-2006, 09:28 AM   #8
kevncar
Active Member
kevncar's Avatar
thanks pjmoreland. I see what I need now. The shaft out of a truck with the rubber boot pivot like on the left of the shaft you have pictured.
thanks
Kevin
72 Chevelle
67 C10...454/TH400
Old 04-03-2006, 09:52 AM   #9
I don`t understand.Is this a van tilt?Why do you need to collapse a truck tilt?Only the van ones need to be collapsed to install in a truck.Or,is it a truck column and you need to collapse to mount the newer steering gear?
Old 04-03-2006, 10:46 AM   #10
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Yes, this is a van column. See how the shaft rod sticks out past the end of the colunm 4 or 5in. This extra has to compensated for by shortening the intermediate shaft.
sneakysnake is offline   Reply With Quote
Old 04-03-2006, 01:03 PM   #11
70c10
67-72 Addict!
70c10's Avatar
What does he need to do with that area circled in red?. I think the one I have has about a 2" stub sticking out from the van column. I'll have to check mine tonight.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-03-2006, 02:16 PM   #12
kevncar
Active Member
kevncar's Avatar
70c10,
From what I have gathered from this, I don't need to do anything with the part circled in red. That is the stock 67, plain-jane, no-shifter, non-tilt column in my truck now. That upper shaft apparently goes all the way through the column and cannot be used with the van tilt. I need to get a shaft off a 69-72 that bolts to the end of the shorter column, like the nice black painted one in the above pictures. Then I just unbolt the pinch bolt holding the rag joint flange on the end of the van colum and bolt on the new truck shaft and after all the mods in the FAQ section, I'm done. I think
Kevin
72 Chevelle
67 C10...454/TH400
