Active Member
67 gauge bezel
Just wondering how desireable a guage bezel (w/ guages) is from a 67. I think it's just the 67s that had the lights and wipers on one side and a choke hole on the other. My 67 has one and I saw one in the junkyard today. Just curious.
Kevin 72 Chevelle 67 C10...454/TH400 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961 |
Roadtrip!
![]() Join Date: Feb 2003
Re: 67 gauge bezel
Around 10-25 bucks on e-bay. Depending on condition and tach or speedwarning. 68 used the same bezel also. Not sure how desirable however...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
![]() Join Date: Mar 2004
Re: 67 gauge bezel
If it was in really good shape i would be interested. How much would you be asking. Thanks Jason
PS. would i need the wiring harness to use it? My 67 is a strip model, no gauges or radio.
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans. 2001 Chevy ZR2 Ext. cab 4x4 (DD) 1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process) 1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project) Last edited by 4bynut; 04-02-2006 at 08:18 PM. |
Active Member
Re: 67 gauge bezel
I might swing back by and pick it up. It doesn't have a tach or any of that fancy stuff, but it is the 7-hole cluster. The only gauges that worked on my 67 was the fuel gauge (for a little while) and the volt gauge. I don't know if this is because the gauges are bad or if there is a problem with the wiring or sending units. I plan on using the info in the FAQ and chasing all this down when I get the motor back in it. It would be nice to have the extra set of gauges in case I do have a bad gauge though. Not to mention the bezel was in better shape than mine. thanks guys
![]() Join Date: Jan 2005
Re: 67 gauge bezel
Yes, you need the wiring harness. Heard that you can blow guages if you don't do it right.
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
