Old 04-02-2006, 08:23 PM   #1
Lakewood90712
1/2 ton vs. 3/4 ton Booster.
I pulled a 72 3/4 K20 Booster/master/porp. valve intending to use it to convert my 71 c-10 to power, now I find out it fits, but is different. Will it still work properly ? (it's the 11" Delco booster)
1987 GMC heavy half Shortwide-GONE
1971 LWB 350/350-GONE
1972 Buick Skylark (80K orig. miles,one family owned)
2002 Currie Phat Flyer (Pit Vehicle) STOLEN
Lakewood90712 is offline   Reply With Quote
Old 04-02-2006, 08:48 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 1/2 ton vs. 3/4 ton Booster.
Yes it'll work, and it is a better piece too.
Old 04-02-2006, 09:32 PM   #3
Rod
It's a better set up than the single style diaphram 1/2 ton ones.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 04-03-2006, 12:35 AM   #4
Lakewood90712
Thank's Longhorn Man and Rod.
Looks like it's time to get off the computer and start bleeding some brakes.
Old 04-03-2006, 12:40 AM   #5
thecatseye66
'68 C-20 396 CST CC
thecatseye66's Avatar
Spoken like a true superhero lover.
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES
01 Jetta Turbo Daily Driver
84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico
thecatseye66 is offline   Reply With Quote
Old 04-03-2006, 12:55 AM   #6
72armyswbtruck
72armyswbtruck's Avatar
AMEN to that
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-03-2006, 10:00 AM   #7
1-PU70
1-PU70's Avatar
The outlets for the master ore different on a 1/2 ton and a 3/4 ton. The 1/2 is front to front, rear to rear and the 3/4 is rear to front and front to rear. If you use the 3/4 master and the 3/4 booster you will be OK but you cant use the 1/2 master with the 3/4 booster the rod is a different lenth. If you want a 1/2 master with the same outlets and the correct lenth for the rod you can use a 1977 master. It uses the same lenth rod as the 3/4 Hope that helps and good luck.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 04-03-2006, 10:17 AM   #8
And,I was told it can`t be done.This is what I plan on my shortbed.Are the proportioning valves the same?
