Active Member
Idea For Lifting A Cab With A Cherry Picker
I Came Up With A Idea After Helping Ron586 Load A Cab Onto His Trailer That I Sold Him Saturday. This Is A Attachment You Could Make To Attach To Your Cherry Picker To Make It Easy To Lift A Cab. This Would Bolt Up To Your Cherry Picker Where The Lift Chain Is. You Would Then Roll The Cherry Picker With The Attachment On It Through One Of The Door Openings And With This Attachment Against The Roof It Would Be A Safe Easy Way For One Man To Lift A Cab. I May Try To Get The Old Welder Out This Week And Make One.
![]() Join Date: Mar 2004
Re: Idea For Lifting A Cab With A Cherry Picker
Looks like a real good idea. Might want to put a rubber mat, old carpet, or something on top to protect the roof. Just my $.02. Thanks for the idea, I'll have to build one when i get a cherry picker. I have a couple cabs I'm going to try and restore this summer. Thanks Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans. 2001 Chevy ZR2 Ext. cab 4x4 (DD) 1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process) 1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project) |
Questionable
i just lifted mine safely using a 4x4 from a realty sign. I used ratchet down straps with a 2x4 wedge to affix the 4x4 to the arm of the hoist. wrapped towels around where it came into contact with the doors. undid the cab mounts, master cylinder, e-brake cable and trailering wires, but forgot to undo the ground strap
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
![]() Join Date: Feb 2004
There is another post around here somewhere with pics and deminsions that work out very well, same principle though
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
There is a write up in FAQ about this.
EDIT:Here it is...http://www.67-72chevytrucks.com/vboa...d.php?t=113397
I think the world needs a drink... ![]() Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd ![]() Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster Last edited by sdkid; 04-03-2006 at 01:46 AM. |
Questionable
here - here's my setup, worked damned well:
two pictures too large to put in thread: http://www.satellitehead.com/images/...moval%2004.jpg http://www.satellitehead.com/images/...moval%2003.jpg and one for prosperity: ![]()
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by Rod; 12-10-2006 at 01:23 PM. |
Having issues
Ive seen it done with 2 cherry pickers, on a 4wd. The driveway was not wide enough to accommodate rolling the cab away from the frame.
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Hey Shifty,
That truck hasn't been painted long has it? I like that color.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
Questionable
it was painted when i got it. home job. good color. i'd like to keep it, but jazz it up w/some flake. i like the color and everything....not many trucks out there that keep this color when stock. guess people dont like green
Junior Member
I love the idea of lifting the cab with the cherry picker. I have one problem with it though that might spark a little debate:
Lifting the cab by the top with the glass installed looks to me like asking for cracked glass. My friend bought a truck with his front glass strangely cracked in the exact same spot on both sides of the windsheild. Upon later examination we found his 1/2 ton truck is sitting on a 3/4 leaf spring frame with 1/2 ton gear. Basically the whole truck was transplanted onto a new frame. We believe he didn't lift the cab correctly and it tweaked the cab and broke his windsheild. Just be careful when jerry rigging up something to lift the cab off your frame. You might bend it to an unrepairable condition. If you wanted to lift it without hurting anything, I would recommend making a jig that would lift the cab from the original cab frame bolt points. You could bolt them in from the inside with the doors off and lift it from the structure that was designed to hold the cab up. I know this would be more difficult to make and more difficult to hook up but in the long run it would be much better than a bent cab. Just my two cents..... |
SIX BANGER
the best way i found to lift the cab with a cherry picker .
is to put all 4 bolts in the cab were it bolt to the frame. with chains to the middle of the cab and hook it to the cherry picker and lift it that way. you will need to hold on to it just to balance it.
http://www.cardomain.com/ride/2597018(NN) 1979 chevy truck swb 454 w turbo400 with buckets 1977 chevy truck swb soon to be 454 1976 chevy dually 454 1969 chevy truck six shooter Last edited by bowtiehotrodder; 12-10-2006 at 11:07 PM. Reason: typo |
![]() Join Date: Oct 2005
I used the back cab mount locations as well, but used the front lower fender mount holes because the extra width made it a little more stable. Worked well and I did it all by myself, though it would have been nice to have an extra set of hands for balance.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread Last edited by SactoJim; 10-04-2007 at 05:19 PM. |
#13 |
I have a couple engine lift plates laying around, and figured i'd just weld one to the floor, and lift it that way. I don't care about the cab, so if i damage it Oh well, it's worth a shot.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
#14 |
Personaly I like the "one man cab & bed lift" way of doing it! You can also use this for lifting a fleet side bed! Plans are done and paypal should be set up this week when plans come back from the printer. Plus when it is all done you fold it up and stand it in the corner
![]() Kevin LFD Inc. Last edited by Rokcrln; 12-11-2006 at 08:42 AM. |
