power drum brakes???
I know when you swap to front disc's you run power brakes, is there a way to run power brakes with 4 wheel drums??
1969 c10 stepside 250 inline six, 4speed granny tranny, 4.11 posi rear end |
Re: power drum brakes???
yup..just install a power brake booster...
hook up vacuum line to engine very easy up grade |
![]() Join Date: Feb 2001
My 67 had em.
sweet, I didnt think there would be a problem, I know I dont have the money to do an all out front disc swap, just lookin for a little help in the whoa department
its all about the +6 inches
You could get power brakes, or non power brakes, on either disk or drum trucks.
Active Member
You should be able to get the booster/bracket/pushrod for a a good deal here on the parts board, that's what I did, look in FAQ for the thread on the install, swaps in a couple of hours, well worth it.
Never try to teach a pig to sing; it wastes your time and annoys the pig! ![]() ![]() My lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". |
I even have a pic of mine for ya.
Questionable
is there a specific booster us non-power drum users should get from the store? just curious ...
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
I tried to use my daughters Blazer master one time and it would not work. I think there are also 2 different boosters.
I purchased my new booster from LMC and it was the same as the one I had. Last edited by Mudder; 04-03-2006 at 12:18 AM. |
Questionable
ive heard the same and my local parts stores never have one in stock that i can measure up and they won't order it for you lest you pay up front. i'd like to find a small-diameter booster with the vacuum hole in it that is a true bolt up to my non-power all-drum truck. i dont know if such a thing exists and i would like to buy it new and at a local parts store. this seems to be one of those elusive parts that generates dozens of posts and nobody every truly gets an answer to.
i have the pedal rod already for booster brakes. i just dont know what booster is a true bolt up and whether its necessary to get a new MC or new prop valve.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 04-03-2006 at 12:06 AM. |
I think I had a rod issue that goes into the master. I can't remember if it was too long or too short. I'm getting that CRS stuff now since I (never mind)
![]() I got my booster from LMC and it was the same that I had. Last edited by Mudder; 04-03-2006 at 12:19 AM. |
Back in the sticks
Your pic does not show a distribution block Mudder? Did you take it out of the system?
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#13 |
hey mudder do you like your rad hose? easy install no leaks? Thanks
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
#14 |
The p valve is on the front crossmember. (77 chassis). The radiator hoses work great but ca't say much for the heater hoses and far as the way they are reduced in size to 5/8. They give you a little sleeve that goes inside of the 3/4 for downsizing and it gets pretty messed up. We ended up glueing the sleeve to the heater core last week to get it to work. I may still have some leaks, not sure yet.
#15 |
I picked up a booster with master and rod off Craig's List for $20. It came off a '69 Burb and looks like it will bolt right up. The Burb was 4 wheel drum as well if I recall.
