Old 04-02-2006, 10:22 PM   #1
dougs69c10
dougs69c10's Avatar
obvious electrical problem?????
Ok so on the way home my dash lights and taillights/brakelights went out on me. I know the obvious fuses and headlight switch, but is there something else I should look for?
It happened after the truck backfired, I dont know if thats any concern to the problem I just figured Id put all the info in when it happend
1969 c10 stepside 250 inline six, 4speed granny tranny, 4.11 posi rear end
dougs69c10 is offline   Reply With Quote
Old 04-03-2006, 12:52 AM   #2
rauto13
saving one more
rauto13's Avatar
Re: obvious electrical problem?????
It's a really crazy thought, but there is a plug underneath the truck on the drivers side frame rail for the brake / tail lights that may have come unplugged? I wouldn't think that would have anything to do with the dash lights though. Other than the obvious fuse, h/l switch that's the only weird thing coming to mind for me.
72 Chevy longbed - now for parts
69 Chevy short fleet - needing some love
70 RS Camaro - needing more love
driver - 96 GMC X-cab
rauto13 is offline   Reply With Quote
Old 04-03-2006, 03:21 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Sounds like the fuse, headlight switch, or a wire problem.
Before anyone chimes in with "It must be a ground"... it isn't. The grounds are always blamed for anything and everything electrical. Since both the dash and the parking lights went out, it is on the circuit that powers them. 99.999999% odds of it.
Old 04-03-2006, 03:30 PM   #4
Brad
Out of the carpool lane.
Brad's Avatar
It must be a ground.
I just had to say it!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 04-03-2006, 03:30 PM   #5
Putter
More Cowbell....
Putter's Avatar
Does ANYTHING electrical work? Wipers, radio, dome light?
If not, check the wire that runs from the junction next to the battery to the fuse box bulkhead (on the firewall by your master cylinder).
Try using a test light to see if you have power just before it goes in the bulkhead.
Just a thought and it's free to rule out!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 04-04-2006, 12:48 AM   #6
dougs69c10
dougs69c10's Avatar
ends up just a fuse, I did find some loose connections though, I would check the radio if it had one lol
