Old 04-03-2006, 01:04 AM   #1
Army_Dude
Allright last round of questions before I make the plunge into this 350 swap...
The 350 currently has an electric fuel pump on it will the mechanical one from my 305 bolt on? What other parts are interchangeable? The Ford doesn;t have power steering either, can I use the pump from my 305? Can I leave off the AIR pump (don't even know what that is). The setup on the front of the block looks the same and I plan on pulling both and setting them side by side and getting the 350 ready to go in. I'll more than likely be working alon. Thansk
By the way, I'll be at a field training excercise for the next week so I'll get back to anyreplies when I can. I should have net access tomorrow night. Thansk again.
Army_Dude is offline   Reply With Quote
Old 04-03-2006, 07:08 AM   #2
beaterC10
Re: Allright last round of questions before I make the plunge into this 350 swap...
All of the accessories from the 305 will install on the 350. The only exception would be if you were installing AC on an engine with an older aftermarket intake. Some of them do not have the threaded boss to mount a brace that runs back from the compressor mount.
The mechanical fuel pump will install on the 350 if it has been drilled and tapped for it. Some of the blocks from the late 80's have the fuel pump boss cast in the block but were not drilled for the pump pushrod or pump attaching hardware.
beaterC10 is offline   Reply With Quote
Old 04-04-2006, 03:37 AM   #3
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
I agree. You're 305 front setup should interchange with the 350. If you're moving to Colorado, you may want to retain the AIR pump. The state requires to maintain whatever smog/emission setup that the stock vehicle came with.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 04-04-2006, 10:56 AM   #4
Army_Dude
Are there vehicle inspections there? A guy from CO Springs told me I didn't have to worry about it.
Old 04-04-2006, 05:48 PM   #5
Prerunner1982
Prerunner1982's Avatar
Army dude, yes they do inspections.. my dad got lucky and aquired an emissions expemtion sticker for his old 85 CJ-7, and i am pretty sure his 66 K10 is too old anyways..
Also, what is your MOS?
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 04-04-2006, 09:19 PM   #6
gldevall
gldevall's Avatar
What year is the 350? It may not have the provision for a mech fuel pump.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 04-05-2006, 06:36 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If it's an earlier 350, the dipstick will be on the driver's side, and will interfere with exhaust manifolds on 80's era trucks.
Secondly, 80's era trucks used the funny 7th bolt hole for the front bolt on the driver's exhaust manifold and the rearmost hole on the passenger side. The earlier 350 heads weren't tapped for the 7th hole.
I learned these lessons years ago putting a 70's vintage 350 into my 83 truck.
Old 04-05-2006, 06:04 PM   #8
Army_Dude
It's a newer 350 not sure of the year. Dipstick is on pass side.
PreRunner, I am currently a 91J (medical supply) I spent 6 years as an Apache crewman/mechanic.
Old 04-05-2006, 07:54 PM   #9
Prerunner1982
cool, i am a 52D (gen mech) and 63B (light wheeled mech).. going on my 8th yr in the guard... I am in a Medical Unit..
Old 04-07-2006, 11:37 PM   #10
KShortell
KShortell's Avatar
Hey, you're an Army Dude, right? I'm an Army brat and now DHS/USCG AUX on the weekends. I moved back home to the Commonwealth, making Virgnia the 5th state I've had my truck registered in.
Keep all your original equipment. You have no way of predicting where you'll be stationed next!
Semper Paratus
Kevin
Semper Paratus
KShortell is offline   Reply With Quote
