04-03-2006, 01:35 AM | #1 |
rookie mistake!
I have changed my oil on my 69 1/2 ton without any problems in the past. I changed it this time when the motor was still warm and the oil hit the cross member and went everywhere! what a mess! any easier way to change oil without it running all over the floor?
rick |
04-03-2006, 01:40 AM | #2 |
Re: rookie mistake!
Cut a piece of cardboard to direct the oil into the pan. It is best to change the oil when it is warm, gets more of the debris out.
I think the world needs a drink... Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
04-03-2006, 03:19 PM | #3 |
its all about the +6 inches
Re: rookie mistake!
actually, the hotter the oil, the better the drain. And if you want to get anal, let it drip for 1/2 hr or so.
What engine do you have in the 69? Personally, I've never had any issues with stock engine set ups. |
04-03-2006, 03:21 PM | #4 | |
67 is sold
Re: rookie mistake!
04-03-2006, 03:22 PM | #5 | |
Re: rookie mistake!
Yeah, my 350 pan drains on the passenger side at the back.... nowhere near a crossmember, and I think my six banger drained at the same spot
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-03-2006, 05:01 PM | #6 |
Re: rookie mistake!
when i remove the oil filter on my six banger it drains onto the cross member,
but i have no issues when draining the oil from the pan.i do use the cardboard trick when removing the oil filter. |
04-03-2006, 10:18 PM | #7 |
Too Dumb To Know Better
Re: rookie mistake!
punch a hole in the bottom of your filter, let it drain before you remove it. Much less mess this way.
04-04-2006, 01:59 AM | #8 |
8 vehicles only 4 that run
Re: rookie mistake!
I usually get a quart of economy oil on top of my required refill amount and after draining to a slow drip, I pour the economy oil in and let it semi flush the oil pan a little more til it slows to a drip, then plug and refill. No sense flushing with $5/qt mobil 1 or the likes.
95 2500 350 w/ 3.73 72 GMC 1500 SWB stepside 65 Chevy C10 SWB stepside 72 Chevy C10 LWB fleetside |
04-04-2006, 06:55 PM | #9 |
Re: rookie mistake!
if you are running mobile 1 ,then I wouldn't flush it like that at all. All you're doing is diluting the synthetic with dino oil.
04-04-2006, 09:47 PM | #10 |
Re: rookie mistake!
hey thanks guys for the tips..i am running a stock 307 engine. The oil drains onto the crossmember.....Brilliant! I'll do the cardboard trick next time. Man what an oil stain I have on my garage floor!....Thanks
Rick |
04-04-2006, 09:58 PM | #11 |
PROJECT 7DEUCE
Re: rookie mistake!
Where is the drain plug at on a 307 I have never had the problem before???
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
