Old 04-03-2006, 11:49 AM   #1
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Drum Brakes Suck!!!!
Wow, I got my A55 handed to me this weekend by one of the rear drums. Finally just had to rip it off by hand. Turned out the shoe had separated inside the drum and was stuck holding the drum on. The only reason I even messed with it, was the wheel cylinder was leaking. Finally got it off and replaced everything inside. Anyone replaced the drums with new ones? I'm thinking they look kind of puny for rear brakes.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 04-03-2006, 01:18 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Drum Brakes Suck!!!!
Do a disc brake swap all around... most of your braking power is upfront anyway.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-03-2006, 01:34 PM   #3
Scrubby
Check out GMTrucks.org
What are guys doing for disc in the back? Any good kits? My drums work ok, but when I swapped in the 3:73 axles, I cleaned an rebuilt the all the workings in the drums.
Scrubby is offline   Reply With Quote
Old 04-03-2006, 02:43 PM   #4
red71cheyenne
Back in the sticks
Bouncy, I will eventually go to discs all the way around, but for right now, budget demands staying with what I got. I just got to get the Blazer on the road and driveable first. Then maybe I'll budget for upgrades. hehe.
Scrubby, Blackbird Customs out of Spokane seems to have some really decent prices for conversions. One of them is a boardmember(drinks2many). Check out their website. I think thats who I'm going to go with when I finally upgrade. Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 04-03-2006, 07:27 PM   #5
Jason915
What I am going to do is go with the 73 and newer K5/K10 rear backing plates and the wider rear drum set up, that combined with a K/20 brake booster and the front disc brake conversion will make a huge difference in stopping power.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 04-03-2006, 10:12 PM   #6
jakeslim
Premium Level Member
jakeslim's Avatar
i changed all four drums and shoes out last fall. New drums made a huge difference. In fact, I barely have to push on the pedal to slow down and stop. I plan on keeping drums all around my 69 to keep it stock. I think that will make a difference in value in a few years.
69 K5 CST stock- 350, 4speed
77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's,
jakeslim is offline   Reply With Quote
Old 04-04-2006, 03:10 AM   #7
ian villeza
Active Member
ian villeza's Avatar
I completely agree, Keeping it as original and stock as possible is my philosophy
ian villeza is offline   Reply With Quote
Old 04-04-2006, 09:48 AM   #8
Jason915
I agree with you if I had a nice 69 CST K5 then I would do the same. For me though my K5 is a base model low options so I am going twards more of a resto mod. Mine is going to be a daily driver so I am building my for low maintenance and turn key reliability. My 70 K5 drum brakes work well when freshly serviced but they are always pulling to one side or another several weeks after they were serviced, I really hate drum brakes on the front
Old 04-04-2006, 11:54 AM   #9
red71cheyenne
Back in the sticks
I finished up the other side yesterday, it was a little easier. Had to grind off the wheel cylinder bolts to get it out, but that wasn't too bad. Still am not real happy with the amount of pedal I am getting, but haven't gotten around to the fronts yet either. May be some air on the driver side as that bleeder is stripped.
Any other tips for the fronts?
2011 K1500 Suburban
2014 K1500 Pickup
Old 04-04-2006, 02:37 PM   #10
Jason915
you may be able to bleed the front brake by opening where the brake line goes to the wheel cylinder if the bleeder valve is rounded too bad to get a grip on it. Just have some one pump it up then while they are holding the pedal loosen the brake line until the pedal goes down you might get all of the air out that way.
Old 04-04-2006, 03:18 PM   #11
red71cheyenne
Back in the sticks
I'll give that a try and let you guys know how it works. Thanks, Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 04-05-2006, 11:13 AM   #12
red71cheyenne
Back in the sticks
Well, pulled the driver side front wheel last night and inspected the brakes. They are like new! Got the bleeder loose as well, so bled the fronts and now I have good pedal. Thanks to all for the help. Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 04-05-2006, 04:53 PM   #13
Jason915
Glad to hear it
Old 04-06-2006, 10:39 AM   #14
Drum brakes are ok.Routine maintainence would prevent the problem you have.All you have to do is when you rotate your tires,slide the rear drums off and take a peak.the shoes don`t wear much between rotations.
Old 04-06-2006, 11:53 AM   #15
red71cheyenne
Back in the sticks
Routine is the word. Of course, it didn't help that my Blazer had been sitting for 25 years! I think once I have them working as designed, they will be fine.
2011 K1500 Suburban
2014 K1500 Pickup
