Old 04-03-2006, 05:53 PM   #1
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Question Question About Blazer Tops
Borrowed this pic from Randy (Teeitup) over on the parts board, someone
else asked this same question and Randy answered it I think, I just want
to make sure because I am switching the tops on my two blazers and the
single wall top will be put on "GQ" so ? is are the caps the same for each
of the tops? or are they different like Randy said? and which one is which?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-03-2006, 08:14 PM   #2
Alexis
Member since 2000
Alexis's Avatar
Re: Question About Blazer Tops
i think the differents caps are from different year blazers. I'm sure the smooth one are for 69-70.
Alexis is offline   Reply With Quote
Old 04-03-2006, 09:18 PM   #3
jcfoote60
Active Member
jcfoote60's Avatar
I agree, I just popped two sets of these, one off of a set of 69 doors (smooth and like the ones on the left in the picture) and the ones on the right are just like the set I removed from my 72 doors.
jcfoote60 is offline   Reply With Quote
Old 04-03-2006, 09:29 PM   #4
pound41
Agreed. My 70 have smooth my 71 ridges. My 70 doesn't even have the drip edges on it. Never has had them on it
pound41 is offline   Reply With Quote
Old 04-03-2006, 10:15 PM   #5
2wdBlazer
The Blazer King
2wdBlazer's Avatar
MOst of the ones i've personally seen had the grooves in them and most of the Blazers i've owned have been 71/72's. I'm sure they are NOT top specific.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 04-03-2006, 11:12 PM   #6
teeitup
Just like to part out trucks!!
teeitup's Avatar
I'm not sure on these, both sets came off 71-72 blazers, one was a double wall. But who knows they could of been changed out, or different doors put on it too. The smooth set if the first set I've ever came up with, most are the grooved ones. I've never had a 69-70 blazer to part out to check and see. It would make sense to me if they were 69 or 70.
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 04-04-2006, 04:59 AM   #7
blazerboy72
Mine is a 71 double wall and has the ones with the ridges.
blazerboy72 is offline   Reply With Quote
Old 04-04-2006, 06:30 AM   #8
trailzen
Wasn't the drip rail a later addition to try and keep water running out of the door?
trailzen is offline   Reply With Quote
Old 04-04-2006, 07:02 AM   #9
Blazer1970
Blazer1970's Avatar
My '70 has a double wall, and no ridges.
Blazer1970 is offline   Reply With Quote
Old 04-04-2006, 08:00 AM   #10
Tynee
I miss this truck.
Tynee's Avatar
Do one style or the other work better for keeping water out?
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 04-04-2006, 04:28 PM   #11
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Good question, I wish someone here would answer this also
Old 04-04-2006, 07:23 PM   #12
badpeanut
Not a bad nut after all..
badpeanut's Avatar
My '71 Blazer:
  • double wall top
  • smooth door caps (like those on left)
  • no drip edges or holes (I added them and significantly reduced leakage)
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 04-04-2006, 07:25 PM   #13
Alexis
Member since 2000
Alexis's Avatar
well my brain come up with is
I'm sure will the flat piece it will/can create pockets between itself and the rubber, there are no precise machined parts. The grooves IMO on the other set are made to put pressure on the rubber so if water some how gets in between there it acts like a barrier with the rubber.
there use to be these plastic piece........maybe someone can post. but they screwed onto the top of the door or top windshield frame and they help channel water.
Old 04-04-2006, 09:05 PM   #14
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
My 72 with double wall top has the ridges...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-05-2006, 09:42 PM   #15
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
69 Double wall, no ridges. Matter of fact, only one door has a cap. The other is flush metal at the top Wonder if the door was replaced at some point....
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 04-06-2006, 10:58 AM   #16
rigon4
rigon4's Avatar
I also have a question what is the diff from 69-72 blazer tops and 73-75 blazer tops a guy a worked with says he has a top for my 71 but he has a 73 and a 74 blazer will a see the diff or are they close. THANKS
rigon4 is offline   Reply With Quote
Old 04-06-2006, 11:48 AM   #17
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Wouldn't interchange if that was your question. WAY different.
Old 04-06-2006, 01:26 PM   #18
rigon4
rigon4's Avatar
I asked because i'm going to go get it this weekend. But if it is not the right top i dont want to bring it home. So could you give me some ID tips and some pic would be nice. THANKS
Old 04-06-2006, 04:04 PM   #19
2wdBlazer
The Blazer King
2wdBlazer's Avatar
this is a 73-75. Note there is no rear hatch as the glass rolls down into the tail-gate. It would have a track for the glass.
http://cgi.ebay.com/ebaymotors/chevy...52854743QQrdZ1
Old 04-06-2006, 10:54 PM   #20
cnshoot
cnshoot's Avatar
72 with single wall had groves but it was a earlly 72 it might just be a mid 71 thing or like you said its been 30 years who knows it they have been changed at one point but i do know this mine are original i bought this truck from the original owner and the only thing that had been changed was a rod bearing
72 cst 2wd blazer sb soon to have tilt manual
72 gmc swb fleet 2wd bb air tilt auto
93 c/3500 crew-cab dually
03 chevy suburban LT quadrasteer c/2500 4x4
cnshoot is offline   Reply With Quote
Old 04-07-2006, 01:23 PM   #21
rigon4
rigon4's Avatar
Thanks 2wdblazer for the help. I should of know that
