04-03-2006, 06:18 PM | #1 |
Power Steering ?
i just picked up a p/s boz and pump for my 72 and was wandering if i have to shorten or change out the column. Any info will help
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done... |
04-03-2006, 11:54 PM | #2 |
Designated A-hole!
Re: Power Steering ?
You should be ok.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
04-04-2006, 06:57 AM | #3 |
Watch out for your cornhole !
No column mods. But, you will need the pitman arm and the rag joint coupler for the power steering box though. They are different than manual steering boxes use.
04-04-2006, 12:07 PM | #4 |
cool thanx guys i got it all, hope to have it all done for the weekend
04-04-2006, 12:58 PM | #5 |
Questionable
also, you might need to notch your bumper support bracket on the driver's side to accomodate for the new box. i just found out (thanks, Tim) this weekend that the later model trucks like the 72 had a different shaped bumper support bracket, so it might not affect you.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
04-04-2006, 05:05 PM | #6 |
I had to clearance the core support mounting bracket on the drivers side to clear the end of the gear box also had to dimple my frame to give me the extra clearance needed for the side of the gearbox body. But the steering colum should fit just fine.
