Old 04-03-2006, 06:35 PM   #1
stope4
Vin Numbers and engines
Would a 71 VIN number be stamped on the correct engine either on the front plate under ac or near the oil filter?
stope4 is offline   Reply With Quote
Old 04-03-2006, 07:55 PM   #2
john
member #16
john's Avatar
Re: Vin Numbers and engines
Heres a couple of sites to look at. John
http://www.nastyz28.com/decode.html
http://www.mortec.com/
john is offline   Reply With Quote
Old 04-03-2006, 10:04 PM   #3
jcfoote60
Active Member
jcfoote60's Avatar
should be drivers side rear, just below the cylinder head on the flat casting and yes directly below is the oil filter.
jcfoote60 is offline   Reply With Quote
Old 04-03-2006, 10:42 PM   #4
stope4
jcfoote, I know there's a casting number on drivers side rear behind the head. Is this what you are talking about?
I am wondering if the VIN was stamped on the engines. My VIN is CE141Z607353. Would some derivative of this be stamped on the engine?
Old 04-04-2006, 12:51 AM   #5
Karl Hoh
A little east of nowhere
Yes, if it's the orginal engine. You should find it on the machined pad area of the block directly ahead of the right side cylinder head. The block casting # is found on the driver's side behind the head.
68 C10 250 4spd
69 C20 327 4spd
69 910 250 3spd
80 K10 350 4spd
76 C60 366 5spd school bus
"THERE'S NOTHING YOU CAN BREAK THAT SOMEONE CAN'T BE PAID TO REPAIR"
Karl Hoh is offline   Reply With Quote
Old 04-04-2006, 06:57 AM   #6
Blazer1970
Blazer1970's Avatar
NO. VIN numbers were not stamped on truck engines until 1973. There is only a block ID number, which can not connect the engine with a particular truck.
Blazer1970 is offline   Reply With Quote
Old 04-04-2006, 10:48 AM   #7
Karl Hoh
I didn't know that. Learned something new today. That's great about this board.
68 C10 250 4spd
69 C20 327 4spd
69 910 250 3spd
80 K10 350 4spd
