Old 04-03-2006, 07:50 PM   #1
randyandtina
fender alignment
I bought a 72 swb c10 the front fenders are not aligned right any hints on the best way to align them properly? Will I have to remove the grill, hood, or inner fenders?
Thanks Randy and Tina
randyandtina is offline   Reply With Quote
Old 04-03-2006, 08:06 PM   #2
rage'nrat638
rage'nrat638's Avatar
Thumbs up Re: fender alignment
welcome to the board....
post some pictures...
it could be bad cab mounts. the doors and fenders might need aligned..
a picture's worth 1000 words
mark
rage'nrat638 is offline   Reply With Quote
Old 04-03-2006, 09:05 PM   #3
randyandtina
The cab mounts are new the po had changed them 3 years ago and never drove the truck I will get some pics tomorrow and post them
Old 04-03-2006, 11:42 PM   #4
krue
Designated A-hole!
krue's Avatar
Welcome to the board from South Mississippi. Pics would help a lot.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 04-03-2006, 11:49 PM   #5
northcountry67
northcountry67's Avatar
I found the best way to align everything is to first make sure the doors are aligned, then remove the cowl (access to the upper fender bolts), loosen the outer to inner fender bolts, loosen the fender to radiator support bolts, then begin the alignment where the fenders meet the doors. You may have to add a shim or two for this. I had to loosen the front cab mounts and add two shims to the drivers side to get the bottom of the driver's fender to match the top. When I put my hood on I found that the hood opening wasn't square so I had to loosen the radiator support and use a friction jack to move it over 1/2" to square up the hood opening. It is a pain, but well worth the effort when you are done.
northcountry67 is offline   Reply With Quote
Old 04-03-2006, 11:49 PM   #6
cduster
Here is a thread from the FAQ
http://67-72chevytrucks.com/vboard/s...ad.php?t=80129
Welcome to the board.
Dan
Good Judgment comes from experience.
Most experience comes from bad judgment.
cduster is offline   Reply With Quote
Old 04-05-2006, 08:11 PM   #7
randyandtina
Hope im not to late here are the pics of my fender and door I might also add that the door closes a little hard and that the fender doesnt fit tight against the core support like the passenger side and it looks good
Old 04-05-2006, 08:13 PM   #8
randyandtina
Here are the rest
Old 04-05-2006, 11:07 PM   #9
cduster
The fellas are gonna hollar at you for that air cleaner.
Nice looking truck.
Dan
Old 04-05-2006, 11:17 PM   #10
rage'nrat638
well the pictures tell a lot...
my truck hood looked about the same way...
come to find out..because the truck had been hit on the passenger side the front end was racked..
i pulled the radiator support bottom bushing off and seen the bolt all the way to the side of the hole, and the hole is like 1 1/2" big. loosed the inner fender bolts all of them and used my come a long pulling from the frame to the core support and heard a big pop...as i pulled it...that was the truck saying thanks for strighting out my neck thats been stuck for 20 years...while with each click i was amazed to see the lines strighten right out...
the whole front end floats on the core support if its not lined up. centered.
every thing else will be unhappy...mark
o hay nice truck by the way brother
Old 04-05-2006, 11:31 PM   #11
Mechdawg
Mechdawg's Avatar
Very nice lookin truck. Im just tagging along this thread now so I can follow it Im about to bolt my front clip on bing on the pain.....
Mechdawg is offline   Reply With Quote
Old 04-06-2006, 12:58 PM   #12
raggedjim
raggedjim's Avatar
Nice truck, no advise on the gaps, but cduster is right about that air cleaner. That style tends to catch on fire (foam is right above the carb and if a backfire occurs it'll burn real fast...) It happened to a 40 Plymouth I had and the thing was hard to put out.
Good luck with the gaps, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 04-06-2006, 01:04 PM   #13
67ChevyRedneck
67ChevyRedneck's Avatar
You said the previous owner changed the cab mounts.... check to see that the cab is sitting squarely on the frame as well as the core support advice. The holes for the cab mounts are also way too big and it's easy to get it off by a 1/2" or more.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-06-2006, 02:03 PM   #14
Back in Black
I suspect your fenders are aftermarket and you will need to do some extra work to get them to fit better. The misalignment at the bottom of the door can likely be fixed by bending in the fender mound on the front of the cab. There is only one mount down there. You could maybe do this with a short two by four and BFH. It looked like your body lines match up vertically, if not, you will need to move the door up or down as needed.
Now the hood fender gap. This is not as easy. Try loosening all the small bolts in the front of the fender with the wide gap and use a come-along between the fenders to pull in loose fender in to get the right gap. You will want to pre-measure since you won't be able to close the hood with the come-along in place. Then if you get the right gap, tighten all the bolts. It may be easy. If this doesn't work, you may need to take the fender off and shave some the radiator support off to allow the above process to work.
Before you do the above, check the gap at the back of the hood, it should be straight with the sill plate. I don't think this is your problem.
Good Luck!
Jason
Back in Black is offline   Reply With Quote
