Old 07-26-2002, 07:31 PM   #1
Solver
Solver's Avatar
Wood floor installation
I am ready to install the wood floor in my truck but wanted to know the best sequence. Do I bolt floor in and then try and drill holes to mount box to frame or do I install floor just far enough in that I can drill mounting holes? Is there a diagram that shows exact box hole locations? What procedure have you guys used? Seems that to drill mounting holes and recess offset washer you would have to drill from top down. If that is how then how are you marking holes? Looks like the frame is in the way to try and drill up through floor.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 07-27-2002, 06:46 AM   #2
sewanhaka62
hi
what i did--put bed together--mount on frame--drilled a small
pilot hole from bottom up--used a hole saw for offset washer[drilled to the outside of pilot hole]--don't drill to deep--than drill 3/8 bolt hole---i am shore there are many ways that will work
luck--bob
sewanhaka62 is offline   Reply With Quote
