Old 04-03-2006, 09:13 PM   #1
JMac11
JMac11's Avatar
350HO and 700R4 Uprgrade
Think I am going with this combo in my Blazer. 373 gears/31.5 tires. Anyone got a similar setup??? Have a 670 CFM Holley unit to put on a Edelbrock Airgap intake...
Might not get the AC rehabbed this summer
JMac11 is offline   Reply With Quote
Old 04-04-2006, 01:36 AM   #2
rigon4
rigon4's Avatar
Re: 350HO and 700R4 Uprgrade
You will have to shorten drive rear shaft and add to front . i have a 87 k-10 425 hp 350, th350 with shift kit, np205, 4.11, with 33 inch tires and only got 4-7 mpg so i would go with the OD trans. I have 71 2wd blazer going to pull 350 out of 87 put a tpi setup on it with BW t-5 five speed.
rigon4 is offline   Reply With Quote
Old 04-04-2006, 09:40 AM   #3
ClassicStyle
ClassicStyle's Avatar
that would be nice, i have a 350/350 combo in my 72, but the th350 is geared for highway. and i have a 305/700r4 combo in my 82. they get similiar MPG, but i lost all my fun down low in my 72.
-Cameron
1972 Dark blue, Cst, Highlander
ClassicStyle is offline   Reply With Quote
Old 04-04-2006, 10:01 AM   #4
Jason915
You will like the low 1st gear in a 700R4 and the OD on the HWY, as long as you have 3.73's and lower then I would defiantly recommend a 700R4. The only thing I would advise you against is the RPM intake the are not for heavy trucks and the loss of low end torque is very noticeable. I ran one in my truck and it would really scream in the upper RPM's but even with 4.10's it didn't tow worth a crap unless it was 2500 RPM and higher. I switched to a EPS intake and 4x4 CompCam and that made a huge difference in low end power. I notice alot of people on this board are using the RPM intakes on big 4x4 trucks but believe me if you go off road and tow with your vehicle it is not the best choice, actually even Edelbrock don't recommend the RPM intakes for vehicles that weigh more than 3600 LBS, and there is a reason for that.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 04-04-2006, 12:36 PM   #5
Musclerodz
Installin a LT-1 and 700r4 in mine. I decided to use a machined adapter rather than the advanced adapter output shaft. There has been some tranny pan clearance issues with the output shaft depending on your front yoke style.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 04-04-2006, 06:59 PM   #6
Paul72
Paul72's Avatar
The 700 is about 1.75" longer than the TH350. If you keep the 205 in the same place and move the engine forward, you can avoid the lengthening/shortening of the driveshafts. Check the FAQ section and search for 700R4 - lots of info on the swap.
Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 04-11-2006, 12:05 AM   #7
13lazer
13lazers' blazers
13lazer's Avatar
Talking Re: 350HO and 700R4 Uprgrade
in my 1970 2 wheeler blazer, i'm running a 385 stroker small block with a 700r4 and 3:73's. i have 33's from my 4x4 that im gonna dump soon. it seems to lug the motor only when i hit the lock up toggle at 2500 rpm's. i have the 670 holley and a holley street dominator intake manifold. my old truck surprises alot of european performance cars in the $60k-$100k range when they cant pull away from me on the freeway. i have a set of 235 70 r15's that i think will solve the motor lugging issue. it should be running at maxi mum efficiency at that point. i recommend this upgrade for anyone who plans on driving their truck alot.
13lazer is offline   Reply With Quote
