Oh,you can't buy that new
![]() Join Date: Apr 2000
with 4 way flashers on, stuff goes crazy??hep me
All the electrical stuff on this 86 works OK (except dash light dimmer) UNLESS I try to turn on the 4 way flashers. at that point if i hit the brake a front park light will come on- dash lights go out - and other assorted nightmares. The switch is JUST a switch inside the column right?? or is it one of those nightmare multi-task switches and it's prolly shorted out inside making the other things go nutty. ANYONE have this before, or as usual ,is it JUST ME
![]() DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: with 4 way flashers on, stuff goes crazy??hep me
I HATE electrical problems with a PASSION!!! I honestly haven't had one do that before. I don't know if I should congratulate you or not. With how the turns are on these, I don't care to guess. I had one that the blinkers were going screwy on me and finally found that it had a bad ground in the rear harness. I am guessing a short too, but no clue where to check, but here is a wordy bump for ya!
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#3 | ||
Until Seventy Times Seven
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
I dont recall ever having to go after one of these or not(hazard switch) or at least not on a 84 -up where everything is inside the column. are they accessible?? I'm sure they must be buried under the turn signal switch.?? DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. Last edited by crossy; 04-05-2006 at 05:25 PM. |
#5 | |
OH the fun continues. the 4 ways work fine now but Oil pressure , fuel and temp gauge bury now when i pull the headlights on. Thought for sure that was a bad headlight switch but i changed it out for a good one and it does the same thing?????????????JUST ONCE i'd like to buy one of these trucks that hasn't got electrical problems. DAVE
I posted this 4 way problem in electrical and got a response that solved THAT problem. now on to the NEXT problem.DAVE
http://67-72chevytrucks.com/vboard/s...d.php?t=195046.
found that problem too. the multi connector in the back of the cluster was not making good contact. even though i had checked it ten times as i was installing the cluster the bottom part was trying to pop out. all gauges work OK, but the OP gauge is going to need a sender(no surprise). it goes high then low back to hgh etc. DAVE
