Old 04-03-2006, 11:05 PM   #1
stope4
BB Alternator Brackets
Can someone tell me what year truck this BB alternator bracket belongs to? 71 or 72 or either one? Also, is it mounted correctly?
stope4 is offline   Reply With Quote
Old 04-03-2006, 11:33 PM   #2
da-burb
"Ochre Ogre"
da-burb's Avatar
Re: BB Alternator Brackets
It is 72 only. Do you have the support rod running from the back side of the bracket to the manifold?
I had that bracket on a 72 BB402 suburban and that support rod actually hit the front nub on the master cylinder.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 04-04-2006, 07:13 AM   #3
Rod
yep 72 only
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 04-04-2006, 09:41 AM   #4
stope4
Are you talking about the rod that goes from the outer edge of bracket down to cylinder head? (my left cylinder head has a boss for mounting this bracket) If you look close at the picture, you can see a bolt where the firewall side of the bracket changes angles. The rod is attached.
Old 04-04-2006, 12:51 PM   #5
1-PU70
1-PU70's Avatar
On my 72BB the alt is on the inside of the bracket and the bolt that adjusts it is on the out side. Makes adjusting the belt easer.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
