Old 04-04-2006, 09:01 AM   #1
Back in Black
Best Way to Polish Grill and Moldings
Dear Board:
Has anyone figured out the best way to polish the grill and molding for a 1970 chev. I am not sure what they are made out of. They are too soft for steel wool and buffing compoud doesn seem to touch it.
Any advise?
Jason
Back in Black is offline   Reply With Quote
Old 04-04-2006, 09:22 AM   #2
shifty
Questionable
shifty's Avatar
Re: Best Way to Polish Grill and Moldings
Take the FLITZ challenge!
I'm curious myself, my front end eyebrows need the help. I think I was either watching a rerun of Trucks! TV a few weeks ago or reading one of the two custom truck mags out there and they showed restoration of a body panel...it was in rough like my eyebrows are right now. the guy used like 400 grit sandpaper, then 1000 grit, then a buffing compound.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
Last edited by shifty; 04-04-2006 at 10:26 AM. Reason: added wrong grit numbers :(
shifty is offline   Reply With Quote
Old 04-04-2006, 09:33 AM   #3
I`m going to try what works on wheels.Start with 600 grit,then 1,000,then 2,000,all wet sanding of course.I guess I`ll use a metal polish after that.The main thing is don`t put scatches in it to get a shine.It takes more to get the scratches out than to get the oxidation off.There are places that do hard anodizing,which is how they were done from the factory.I suppose they could be chromed if the price was right.Haven`t checked into that.But,alot of the cost of chroming is in the prep.So....
Old 04-04-2006, 10:18 AM   #4
cstanley
cstanley's Avatar
"Start with 600 grit,then 1,000,then 2,000,all wet sanding of course.I guess I`ll use a metal polish after that."
i have the Tom Brownell book How to Restore Your Chevrolet Pickup, and i believe that's the way he does it. just don't use a power tool to do it. it needs to be done by hand or you'll go right through the metal.
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 04-04-2006, 10:33 AM   #5
smokekiki
Mike
smokekiki's Avatar
You can buy anodize remover,or use oven cleaner.Do not let the oven cleaner dry.Couple times of using the oven cleaner will remove a lot of the anodizing.Then do the sanding and follow with a good aluminum polish.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
