04-04-2006, 10:45 AM | #1 |
Junior Member
Manual transmission options?
Hi folks! I have now purchased a 3rd truck, crazy I guess. It has a 3 spd on the column, I want at the least to put a shifter on the floor. I know everyone is into automatics. What else can I put in? 4 spd? From what? I have seen nothing about anyone putting in a newer 5sp, maybe they won't work. Thanks! I will be needing lots of help. Decided this was a great site also and just subscribed!
04-04-2006, 10:48 AM | #2 |
1972 GMC 2006 GMC
Re: Manual transmission options?
I put a Richmond 6 speed in mine. Fits nice!!
04-04-2006, 11:01 AM | #3 |
I'm going to be putting in a super T-10 4 speed, and hopefully someday upgrade to a Tremmec 5 speed.
I prefer manual over slush box any day of the week. |
04-04-2006, 01:44 PM | #4 |
'69 Step
muncie 4
04-04-2006, 02:21 PM | #5 |
I will be tossing the granny 4 for a 5 (or 6) after everything else is done. I bought my truck because it was a stick.
Auto's can be cool, but I would rather shift my truck. |
04-04-2006, 03:24 PM | #6 |
Junior Member
I love sticks myself, glad to see there are some of us. I do want something besides the 3 on the tree though.
04-04-2006, 03:28 PM | #7 |
personally I like the old granny low 4 speeds.I'm using one with dual glass packs behind headers and I have 3.73 gears in the rear this baby wont when many races but it will be telling me a story or two going down the highway.
04-04-2006, 05:31 PM | #8 |
i put a sm465 4 speed in place of my 3 speed.it was donated from a '68 c-10.
04-04-2006, 05:36 PM | #9 |
Im using the gm 3 speed with a floor shifter. Love the manual tranny not sure if this one will work out or not but I would prefer to stay manual. Probally go richmond 6 later on....
04-04-2006, 05:50 PM | #10 |
I have a line on a vette 6-speed for $1500 and or a 5-speed for less, but I also want a TKO 5-speed for my 70 Camaro. If I do that $3k!! I'll be selling the rebuilt muncie from the Camaro, I was not aware that this was a common swap (car trans in a truck?) Learn something new every day.
04-04-2006, 06:32 PM | #11 |
Registered Cruiser
saginaw 4-speed from a 2nd gen. camaro.. cheap, and easy..
I intend to live forever. So far, so good. |
04-04-2006, 07:28 PM | #12 |
would love to have one in mine
04-04-2006, 09:34 PM | #13 |
I have a nv3500 from behind a 4.3 v-6 s-10 truck. This same tranny was used on the 88-98 C1500 half ton trucks. (I have a 92 bought new with this same tranny) This tranny is fine for a stock type output engine.
I got the tranny, clutch assembly, driveshaft and flywheel for $600 from a local junkyard. It came out of a low mileage totaled truck. You can convert the speedometer using any number of conversion mechanisms. I will only use the tranny and the flywheel(resurfaced) and new clutch assembly.
ongoing 1970 c 10 lwb 1994 z-28 few mods.-owned since new 1978 vette silver/grey 25th anniv. paint |
04-05-2006, 12:04 AM | #14 | |
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
04-05-2006, 12:11 AM | #15 |
the easiest thing would be a four speed saginaw from a vega or camaro. same input and and output shafts and same lenght and no driveshaft mods. hurst makes a shifter for the you can get at jegs.com. there pretty strong. heard there as good as munci's. i've got one in my 69 and have been giving it hell with no problems. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
04-05-2006, 12:12 AM | #16 |
Try to find a 4 speed with overdrive from a 81-87 1/2 ton, thats my favorite.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
04-05-2006, 08:13 AM | #17 |
How about an early 3speed with overdrive---. Cheep and effective.
04-05-2006, 03:02 PM | #18 |
Junior Member
I have a 72 step that I have a Hurst shifter I want to put and get rid of the three on the tree and put a new column in along with p/s, but not sure if the shifter will hit the bench seat or not, maybe someone can chime in with thoughts on this.
1970 SILVER CORVETTE COUPE AUTO 1971 SILVER CORVETTE COUPE 4 SPEED 1972 RED C-10 STEPSIDE 3 SPEED 1985 WHITE S-10 BLAZER AUTO 1998 WHITE S-10 4WD PICKUP AUTO 2006 SILVER H-D DYNA LOW RIDER Last edited by JIMS1972STEPSIDE; 04-05-2006 at 03:04 PM. |
04-05-2006, 03:06 PM | #19 |
My 69' had a Hurst shifter installed to replace the 3 on tree and it was close to the seat but it didn't hit it. Mount it a little bit forward and it should be OK.
04-06-2006, 11:17 PM | #20 | |
04-06-2006, 11:53 PM | #21 | |
sag's are about $200 around here and m22's around $800ish. that's that enough said. my sag's been holdin up fine in my '69 and i've been givin it hell. chris.
04-07-2006, 12:27 AM | #22 | |
Still drivin' a Rat Rod
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
04-07-2006, 08:22 AM | #23 |
Can`t beat a Muncie.They don`t call them Rockcrushers for nothing.I only made my comment because it was said A Saginaw was the easiest way to go and the Muncies are just as easy,that`s all.One day I was home,broke,and bored.I couldn`t afford a lock-washer.I went outside to see how far I could get with pulling the 3spd to make room for the M22 I had to go in.Got the 3spd out in about 1/2 hour,so I got the M22 to hold up to see what I needed.By the time my room mate was home from work I had already taken it out for a trial run,nothing bought.I`d have driven it more,but no gas money.I was happy when he said he`d put some in it if we drove it somewhere that evening.
04-07-2006, 08:41 AM | #24 |
The oddest Todd around
What does it take to convert an auto to a manual?
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
04-07-2006, 10:13 AM | #25 |
The clutch pedal,linkage,and z-bar and trans tunnel.Which are fairly easy to find in salvage yards.Of course bellhousing,clutch,pressure plate flywheel ect.
