Old 04-04-2006, 12:20 PM   #1
Luba
Luba's Avatar
79 Ford HP dana 60 front in a 72k5?
Anyone ever put hp 60 in front instead of a chevy 60? I already have a hp 60 and a 14 bolt to swap in my 72, which should I use?
Luba is offline   Reply With Quote
Old 04-04-2006, 12:24 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: 79 Ford HP dana 60 front in a 72k5?
Isn't the ford drop is on the other side?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-04-2006, 04:14 PM   #3
Luba
Luba's Avatar
Yes it is on the other side, I would swap the t-case too.
Old 04-04-2006, 04:29 PM   #4
bouncytruck
SKINNY TIRES RULE!
Sounds like more trouble than it is worth. you'll have issues with the output shaft from the transmission to the t-case. You may also have to alter your rear drive shaft (if the u-joints are different for the ford vs chevy).
I'd just find a chevy axle and make it easier on yourself.
bouncytruck 1972 K5
Old 04-04-2006, 05:43 PM   #5
70rs/ss
70rs/ss's Avatar
I was thinking of doing something along these lines because the newer trans cases are left hand rather than rt on the older stuff a F***front might be the fix. I'd have to be sure, but the rear is a center deal on either (if I am not mistaken) 6.0 motor, 4l60e/x-case and a f*** front axle?! Could be...
70rs/ss is offline   Reply With Quote
Old 04-04-2006, 05:53 PM   #6
krebsatm02
What is the purpose of this vechicle?
You do know that the 78-79 ford is the most desirable 60 there is because of it's High pinion and spring pirch width?
I'm using a ford 205 in my rock buggy that has a Ford HP60. Ford 205's have good components in them: big bearing case, 32 spline front and rear outputs.
The drive train in my buggy will be 4.3TBI/SM465/241 Planetaries/Ford 205
krebsatm02 is offline   Reply With Quote
Old 04-04-2006, 07:30 PM   #7
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I am pretty sure VTBLAZER has one in his trail blazer.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 04-05-2006, 06:14 AM   #8
vtblazer
vtblazer's Avatar
Yep...
79 HP Dana w/furd 203-205 doubler behind the th-400
vtblazer is offline   Reply With Quote
Old 04-05-2006, 06:19 AM   #9
vtblazer
vtblazer's Avatar
Just in case your wondering why the spring pack is flattened out in the above pic.
I was checking for clearance.
Old 04-05-2006, 07:42 AM   #10
Luba
Luba's Avatar
Yes I know that hp 60 is the good one. I already have one sitting in my pole barn. I bought it for SAS on my 97 yukon(never completed). I would have to buy the chevy 60. I also already have a 14 bolt FF with 4.56, detroit, and disc brakes already rebuilt- ready to go (already sitting in rear of yukon). I want to have a daily-driver capable blazer (72) that will see trails, dunes, mud bogs/drags, and sand drags. I just wonder what work is involed with the tranny and t-case issues- the rest of swap is no big deal to me. Is this swap worth it or should I just buy a matching chevy 1 ton set of axles from my bud. They are already 4.56 would have to add detroits and rebuild them?
Old 04-05-2006, 07:47 AM   #11
I`d do it.I wish I had one.I have a NP241 LH-drop/NV4500 with under 20,000 miles from my wrecked`95 I`m dying to use.
You could sell it and buy a GM axle.This is the axle used for straight axle conversions on IFS GMs and serious-duty Jeeps.You could go either way.You`re in a good position having it,either way.
