![]() Join Date: Jun 2005
Steering box adjustment?
Is there an adjustment on these steering boxes to remove excess play? It's a manual box on a 70 2wd 1/2 ton. I thought I saw something on this a while back but I couldn't find it. Thanks for any help.
Mark
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Steering box adjustment?
Yes there is.
Loosen the locknut on top of the box with a 5/8 wrench while using a screwdriver to keep the middle screw from turning. Now, turn the screw clockwise to remove slack and then hold it while tightening the locknut back up. Don't tighten the screw too much though, or you'll get a stiff spot in the middle of the steering travel. If so, back it back off enough to make the steering turn smoothly lock to lock.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 04-04-2006 at 01:39 PM. |
Thanks for the help, anything else I shoud know?
It's a catastrophic success.
![]() Join Date: Jan 2003
A little extra info
http://67-72chevytrucks.com/vboard/s...d.php?t=187945 |
What kind of lube in inside these? how do you rebuild them?
Thanks sneakysnake.
Mark
Sorry about jumping in on your thread but i tried the adjustment thing for mine and it feels a lot better now.
Thanks Tim |
