04-04-2006, 04:26 PM | #1 |
Next project: 1970 K10
How the &@#! do you install the front rubber bumpers in the A-arms?
First of all, I made the mistake of not putting them in BEFORE I installed the front end. Now that I realized I left them out, I am going through all the skin I have left trying to get then dern things in.
Any suggestions on how to get them in, both upper and lower, without having to pull the spindle and spring??
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
04-04-2006, 05:53 PM | #2 |
Watch out for your cornhole !
Re: How the &@#! do you install the front rubber bumpers in the A-arms?
I have warmed them in the microwave to soften them enough so that they pop in easier. Ten seconds or so is all it takes.
04-04-2006, 05:59 PM | #3 |
Thanks TX, I'll give that a try. Getting tired of losing skin on my knuckles! But I'm just glad to be working on this thing again. It was getting lonely!
04-04-2006, 07:04 PM | #4 |
I tried TX's method but wasn't successful.
What I did was drill a hole on the front side of the bracket that holds the bump-stop to be able to get a grip on the bottom of the rubber using some needle-nose pliers. I lubed the bracket w/some dishwashing soap & pushed down on the top while pulling w/the pliers. They popped right in.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-04-2006 at 09:24 PM. |
04-04-2006, 07:07 PM | #5 |
I have heard that freezing them makes them slightly smaller. Most materials contract when cool and expand when warm, except water of course.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
04-04-2006, 09:45 PM | #6 |
I used wd-40 on mine and they went in pretty good
04-04-2006, 09:49 PM | #7 |
sometimes when you freeze rubber it will be brittle, so it is easier to rip or crack it
04-05-2006, 12:07 AM | #8 |
I never did get my new repop lower bumpers in, may be they were made a little off, I ended up putting the old ones back in, they were a little loose, but they fit. I even cut a block of 2x4 to wedge between the frame and the bumper, jacking the front to compress the crap out of it, used all kinds of lube, but no go. I just gave up after so many hours wasted on something so simple.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
04-05-2006, 12:10 AM | #9 |
Thanks for all the suggestions! Maybe I'll try a little heat and some grease!?
04-05-2006, 12:26 AM | #10 |
If all else fails give the freezer a try. It won't hurt them. If it did we would all (or all of us up North) be in trouble during the winter
Here's an article at Engineers Edge that mentions the freezer trick. http://www.engineersedge.com/bearing..._press_fit.htm Here's a thread on Yesterday's Tractor that mentions the same trick. http://www.ytmag.com/crawlers/messages/32879.html
04-05-2006, 12:50 AM | #11 | |
Avatar is a pic of "Before"... Just wait.. ---------------- 1969 Fleetside: Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans. 20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit). Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all ---------------- Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!! |
04-05-2006, 01:52 AM | #12 |
Silicone lube is the best lube for inserting rubber in confined spaces or holes. Paste or spray, it's slippier than soap. Harmless to rubber, too, unlike petroleum based lubes.
I would think that freezing would add stiffness making insertion difficult. Clean jokes only, please.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
