Old 04-04-2006, 07:13 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Lower a-arm help..
Does anyone know if I can use the lower a-arms off a 71-72 disk brake front end on a 65 with drum brakes or do I have to swap over to the disk spindle to make everything work???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-04-2006, 07:16 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Lower a-arm help..
If I remember correctly, the control arms the same, but the ball joints are different on the 71-72's.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-15-2006, 09:37 PM   #3
el curioso
el curioso's Avatar
I have a another question and it follows:
Are the ball joints from the top and the bottom the same from a 1969 and a 1972.cuz i plann on changing out the suspension from 1972 truck to a 1969.
Thanks in advance and sorry for the stupid ??.
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 09-15-2006, 09:46 PM   #4
junkyardjohn
junkyardjohn's Avatar
I ALWAYS JUST SWAP OUT THE WHOLE CROSSMEMBER. IT DOESN'T SEEM TO BE ANY MORE WORK IF THE MOTORS OUT. & IF YOU ARE GOING TO REPLACE ANYTHING... NOWS THE TIME WHILE THAT HEAVY SUCKER ISN'T UP UNDER THE TRUCK. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 09-15-2006, 09:55 PM   #5
68C15
blood type; Retumbo
68C15's Avatar
disc joints will fit right into/on drum armsand vicea/versa.
68C15 is offline   Reply With Quote
Old 09-16-2006, 11:21 PM   #6
el curioso
el curioso's Avatar
tha you for all your help. it really helped ill take some pics after in done.
