Old 04-04-2006, 07:37 PM   #1
jermasaurus
jermasaurus's Avatar
Bolt Pattern?
Does anyone know for sure if a TBI 305 from a 88 Firebird is a chevy bolt pattern as far as bellhousing bolts? Or would i need a Buick/Olds/Pontiac pattern trans (meaning I would pass on the motor)
I am 99% sure it is chevy, but can someone please verify?
-Jeremy
79 Jimmy slammed AKA James Down
jermasaurus is offline   Reply With Quote
Old 04-05-2006, 01:28 PM   #2
60-66 Nut
Professional Beer Tester
Re: Bolt Pattern?
Jeremy, if it is the 5.0 305, which my Wix filter book shows it should be, that is the Chevy 305. The 5.0 307 would be an Olds engine which uses different engine mounts and bell housing pattern. The Olds engine is easily identified by the oil filler located in the intake manifold and only 5 head bolts on the bottom row. The different bell housing pattern is easily fixed with a BOP adapter, they work just fine. The engine mounts are a little harder to adapt.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 04-05-2006, 01:30 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Bolt Pattern?
Its a Chevy. Anything 82-up is all Chevy.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
