Old 04-04-2006, 08:05 PM   #1
smills78gmc
AC bracket/header clearance
Anyone running headers and drivers side AC . Flowtech headers will not allow me to install bracket for the back of the compressor. Anyway around this? Different headers? Please Help.
smills78gmc is offline   Reply With Quote
Old 04-04-2006, 09:01 PM   #2
beaterC10
Re: AC bracket/header clearance
You should be able to modify the stock bracket to fit around the header tube. If I remember correctly you have to cut part of the bracket off and clearance the bracket to get it to fit. You will probably also have to use a stud and some spacers on the first one or two header bolt locations. I had to do this on a truck a few years back.
I have to do this to my current truck in the next few days.
beaterC10 is offline   Reply With Quote
Old 04-04-2006, 10:41 PM   #3
texan1186
Under Major Construction
texan1186's Avatar
here is a pic of my setup. i have the flowtech headers too.
1982 Chevy Silverado 350/700r4
see it here
texan1186 is offline   Reply With Quote
Old 04-04-2006, 11:35 PM   #4
f.monroe
f.monroe's Avatar
Cut the back of your bracket like his picture shows . Then take one of the original bolts that has the studded end from one of the first two holes . Run a 3/8 inch nut on the threads that originally went into the head . Thread the stud through the header just like a header bolt and use the nut to tighten against the header . The other end is the studded end that should be in the same place it was (same spacing) as when it was originally installed in the cast iron manifolds . Then you can place the bracket over the stud , use another nut to secure it to the stud , and it should be good to go . This is how I di the A/C on my 77 I had in High School . I hope it makes sense because it is the easiest way that I found to mount the AC without having to buy an extra bracket . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 04-05-2006, 07:05 AM   #5
smills78gmc
Thanks, but I think my bracket is different. There is a piece that bolts between the second and third header bolt. I think I will try to find the same bracket that you have. It will be much easier.
Old 04-05-2006, 07:53 AM   #6
beaterC10
That bracket seems to be pretty common on trucks and Impalas
Old 04-05-2006, 05:07 PM   #7
live85
live85's Avatar
You are doing the right thing. Don't try to run without that bracket. I cracked my compressor by running without it.
Mike
1985 White Custom Deluxe LWB
Early 70's 350 / stock turbo 350
2.73 open differential 10 bolt (yeehaw)
Priceless sentimental value
live85 is offline   Reply With Quote
Old 04-05-2006, 06:28 PM   #8
smills78gmc
Do the different brackets go with different compressors? Or will the other bracket work with my comp.? The reason I ask is arent there like 3 different comp. for these trucks?
