Old 04-05-2006, 01:17 AM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
Crossmember chop?
Been lurking and searching the crossmember chop posts and have a few unanswered questions.
1) What major snags are common to the process?
I have noted:
- Steering shaft interferes with upper a-arm. Appears to be pretty straightforward
- Tie rod end interferes with crossmember, is this both, or one side, and where?
- Any steering geometry issues that need to be worked out? Bump steer issues?
2) How is the cut made so as not to have to add filler material when reassembling?
3) What is being done in the back to even the stance? Blocks? Lower rear bag pressure than front? Both?
Anything else that I am not thinking of that I will be blindsided by?
Thanks -Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-05-2006, 09:19 PM   #2
TravisH
TravisH's Avatar
Re: Crossmember chop?
1) I haven't done this so I can't help you there
2) The cut is 1 1/2" right? Use some 1 1/2" masking tape to trace your upper and lower cut lines. Just follow with the zip and you've got parallel cuts
3) If you're doing the front crossmember drop its usually to get the front closer to the ground. If you want to lower the back more you'll have to put in a fair sized notch
TravisH is offline   Reply With Quote
Old 04-06-2006, 03:31 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Yeah, with a straight peice of tape I figured that because of the irregular shape of the member that there will be gaps left. Just lookin' for hints to ease the process. Thanks for the reply.
Anyone else?
-Chris
Old 04-09-2006, 11:45 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
No further guidance?
-Chris
Old 04-10-2006, 10:39 PM   #5
nwmod39
nwmod39's Avatar
http://www.captkaoscustoms.com/
1980 c-10: under destruction
http://photobucket.com/albums/c372/nwmod39/
nwmod39 is offline   Reply With Quote
Old 04-13-2006, 10:11 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Make sure you make nice cuts so that you dont have to add filler pieces later like I did.. The link above in is the best info I have found..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
