Are 67-72 A-Arms All The Same??
Are the A-Arms all the same on 67-72 models? I know that the spindles of course are different on 5 lug and 6 lug trucks, but will the A-Arms off of a drum brake truck work on a disc brake truck??
Also what is the difference between 67-68 Radiator Supports and 69-72 Radiator Supports?? ![]() |
#2 | |
Bloo
im not sure on the a-arms, but i think headlght location is different on the radiator supports
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
BOWTIE FOREVER
YES they will but you need to use the same year ball joints and a-arm bushings on the disc brake ones that you want to use.
Don't know about the other. ![]()
69 C-10 SHORT FLEET BED 350 4-BOLT/400 turbo upper & lower molding 65 IMPALA 2-DR 283/POWERGLIDE 66 IMPALA 2-DR hopefully 283/350 ~ CAMELTOE ROCKS ~ |
The steering stops on the a-arms are different form drums to disc trucks. if you put a 71-up spindle on your drum brake a-arms, it will cause your turning radius to be longer. I don't think the change is much though. However, I think early classic 67-70 disc spindles are made to counter act this.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
