Old 04-05-2006, 07:55 PM   #1
outacontrl86
went off roading today
soory i dont have any pics but i will see if i can get some but i have a question.
1) when i went to go up a hill my truck seem to stall on me al the time(lack of gas?)
2) my master cylinder brake cover blew off and fluid went every where(why?)
3) i noticed when i was almost done alot of anitfreeze on the ground. i thought i blew a head gasket but i am not sure.
the motor has 153.000miles on it. not sure if it was abused or not b4 i got it but ii have out it through the paces. so why did i see anitfreeze? thanks
outacontrl86 is offline   Reply With Quote
Old 04-05-2006, 08:01 PM   #2
Prerunner1982
Prerunner1982's Avatar
Re: went off roading today
how steep was the hill you were trying to climb, too steep and your carb was starving for fuel...
not sure on brake issue..
as far as antifreeze on the ground.. if its on the ground its probably not a blown headgasket as it usually goes into the cylinder and gets evaperated or blown out the exhaust.. if it was under the front of the truck i would guess hole in the radiator hoses or radiator itself, of coolant is leaking out of the weep hole in the bottom of the waterpump, which is a good indication that your waterpump is going out.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 04-05-2006, 08:16 PM   #3
outacontrl86
alot was on the fuel pump like in that area and i am now thinking about it and it may be the manifold? mabye not sure.
yes the hill was steep but wasnt to bad. another guy did it no problem with his truck and that was carb truck
Old 04-05-2006, 08:39 PM   #4
bcolli3
'72 4x4 fireburb
I've had my truck almost vertical and it kept running great. The problem is when I'm off camber gas starts pouring out of the filler neck. Then, when I go the other way the beer rolls out of reach.
'72 GMC Suburban 4x4
'93 CBR 1000
'83 G20 beater
'88 F-150 - for sale
bcolli3 is offline   Reply With Quote
Old 04-05-2006, 10:16 PM   #5
Prerunner1982
could be your carb isnt adjusted properly..
i dont think it would come out of the manifold unless the seal around where the waterneck meets the intake was messed up or if the hose wasnt tight around the filler neck..
Old 04-06-2006, 12:38 AM   #6
72 CustomCamper
huh ???
72 CustomCamper's Avatar
It also depends on what carb is on the truck...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 04-06-2006, 06:36 AM   #7
outacontrl86
it has a holley 600 and a edelbrock intake yea i think the carb needds to be gone over
Old 04-06-2006, 09:47 PM   #8
72 CustomCamper
huh ???
Holly's are not fond of being on inclines. When you went up hill it probably flooded the front bowels and starved the rear bowles...
Chuck
