04-05-2006, 08:06 PM | #1 |
another electrical problem
I keep popping my tail lights fuse, I covered all exposed wires, tightened loose ends and replaced the fuse, I turned them on when I got home from work and they are out, fuse is popped again, bulbs are correct, wiring is right.
Im scratchin my head at this, I even traced the wires down the truck to see if its exposed and none of the wires exposed. No archin or sparkin while on.
1969 c10 stepside 250 inline six, 4speed granny tranny, 4.11 posi rear end |
04-05-2006, 08:32 PM | #2 |
Re: another electrical problem
It sure sounds like a short? You might want to try posting this on the electrical forum also.
04-05-2006, 08:54 PM | #3 |
C10 Club Tennessee
It's probably your turn signal switch. Try taking off the steering wheel and backing the three screws that hold the turn signal switch by a LITTLE bit. or just replace the whole thing.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
04-06-2006, 01:16 PM | #4 |
It's a catastrophic success.
Unplug the 4wires that go to the tail lights at the fire wall(right above the gas pedal) this will eliminate all the wiring down the frame and to the bed.Put in a new fuse if it blows again then you will need to check the wiring to the front park lights or you have a in dash problem.
