Old 04-06-2006, 12:23 AM   #1
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
I'm in trouble with the wife
I bought a 70 Jimmy without telling her. OOPS! Well we've been married 27 years and we'll survive it.
The real question I have is about swapping front suspensions. Would the crossmember from a 2wd bolt right on? I have a lowered 67 with disc brakes, etc... What about the lowered coils on the rear? Would I be better off using the leaf springs and lowering them?
Thanks.
low'n slow is offline   Reply With Quote
Old 04-06-2006, 01:40 AM   #2
Pop's72
It's ok to stare...
Pop's72's Avatar
Re: I'm in trouble with the wife
Well if you are going to get in trouble it might as well be for a good reason.
Congrats and you knew this was coming...
Pop's72 is offline   Reply With Quote
Old 04-06-2006, 08:57 AM   #3
low'n slow
low'n slow's Avatar
I haven't seen it yet myself. But here it is.
Old 04-06-2006, 09:01 AM   #4
Rokcrln
Rokcrln's Avatar
The front will bolt up but you have I belive one hole on each side you will need to drill. The rear is different at the axel location, leaf spring rears are strait and coil rears have a small bend the the frame right above the axel. What you can do is use the trailing arm cross member and arms then just mount coilovers/ bags behind the axel on the out side of the frame or build new mounts in front of the axel in the stockish location. I have a guy right now who wants the total rear suspention I am removing from a customers 2wd blazer (cross member, axel, arms,coils, panard bar) to convert a 4wd to 2wd. I just have not decided what it is worth so my customer gets the most out of it while still being fair to all.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 04-06-2006, 09:10 AM   #5
Rokcrln
Rokcrln's Avatar
Looks good! Now what I want to know with snow still on the ground how could you even tell you were getting the cold shoulder from the wife. What did she trap you in a corner and force you to listen!
Kevin
LFD Inc
Old 04-06-2006, 10:24 AM   #6
Livrat
Member #1049
Livrat's Avatar
Actually you will have to drill about 2 dozen holes.. both for the 2WD front crossmember and Trans crossmember (I have done a half dozen
4X4 to 2WD Blazer/Jimmy conversions in the last 20 years or so) There is a lot more work involved if you want the coil spring rear.. I opted to use the leaf springs and put the rear axle on top of the springs.. It worked perfect for the ride height I was wanting.. There could be more front frame horn mods depending on your ride height...
Here is a picture of a Jimmy that I converted...
Livrat is offline   Reply With Quote
Old 04-06-2006, 10:34 AM   #7
So far that Jimmy has lasted longer than your marriage.Just tell her that.lol
Old 04-06-2006, 03:24 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-06-2006, 04:54 PM   #9
Rokcrln
Rokcrln's Avatar
You are right I was half asleep when I saw this and was thinking of the 73 and up 2wd cross members in the 72 and down frames I have done
Kevin
LFD Inc.
Old 04-06-2006, 08:07 PM   #10
67_C-30
I have a radical idea!
67_C-30's Avatar
Good buy! I was watching that one on Ebay myself.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 04-06-2006, 09:39 PM   #11
low'n slow
low'n slow's Avatar
It has has been in the 60's and 70's here. Colder this weekend, but it won't last. She calmed down and it wasn't as bad as it could have been. I have promised not to play around on ebay for a while.
It sounds like it may be easier to take 11 inches out of my short stepside frame than transfer the suspension.
Old 04-06-2006, 09:42 PM   #12
low'n slow
low'n slow's Avatar
That didn't help. She has become proficient with sign langauge though
Old 04-06-2006, 11:29 PM   #13
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Looks like a great base for your project! Good luck with it
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 04-07-2006, 12:03 AM   #14
smbrouss70
smbrouss70's Avatar
Has anyone tried this approach before?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 04-07-2006, 12:18 AM   #15
jrb71c20
jrb71c20's Avatar
If after 27 years of marriage, mine hasn't killed me yet...I may do the same kind of thing cause I won't get that medal I shoulda recieved for lasting 27 years on the front line...
jrb71c20 is offline   Reply With Quote
Old 04-08-2006, 11:37 PM   #16
low'n slow
low'n slow's Avatar
Went to pick up the Jimmy today. Good and bad news.
The Bad:
Alot more rust than I was led to believe
It leaked oil all over the driveway when I got home.
The Good:
Original sales order sheet, window sticker, Proteco Plate, Owner's manual with the nifty evelope that the dealers give you. It has Positraction, and a lighter delete.
I'll post pictures tomorrow.
Old 04-09-2006, 12:07 AM   #17
1976K5CHALET
1976K5CHALET's Avatar
Colorado? I'm a guessin front range as i have yet to find someone from this board from western colorado...
DW
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
Old 04-09-2006, 12:41 AM   #18
low'n slow
low'n slow's Avatar
In the Springs
