Old 04-06-2006, 08:51 AM   #1
Solver
Solver's Avatar
2 different Inner Rocker panels
Wasn't sure if this was common knowledge so I thought I would post this.
Ordered new inner rockers to put on my truck and got something different this time. I usually recieve the flat plate that goes in back of the rocker panel(bottom pic) but this time I got a inner panel with the wire channel built in (top pic). Now if you are replacing floors the top one with the channel won't work well as it is hard to match up with new floor channel shape. If I was just replacing rockers and inners this would be great as alot of times if the rocker is bad so is the groove that the wiring sets in. With this top panel it may save having to buy a flor panel like I usually do just to be able to cut off the outside edge to have that channel. Also need to be careful when ordering as these are both called inner rocker panels.Sorry if this is old news to you but it was new to me as I had ordered 4 inners and had to reorder 4 flat inners from someone else.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 04-06-2006, 10:23 AM   #2
matthufham
Re: 2 different Inner Rocker panels
hmm. interesting. that should keep the water out and keep stuff from collecting in there. i don't even use inner rockers for that reason... and i didn't know how to install them.
matthufham is offline   Reply With Quote
Old 04-06-2006, 10:28 AM   #3
Karl Hoh
A little east of nowhere
Who was the supplier?
68 C10 250 4spd
69 C20 327 4spd
69 910 250 3spd
80 K10 350 4spd
76 C60 366 5spd school bus
"THERE'S NOTHING YOU CAN BREAK THAT SOMEONE CAN'T BE PAID TO REPAIR"
Karl Hoh is offline   Reply With Quote
Old 04-06-2006, 10:30 AM   #4
rigon4
rigon4's Avatar
were did you get the inners with the wire path from, and do you have the part number Ineed a set like that. thanks
rigon4 is offline   Reply With Quote
Old 04-06-2006, 02:01 PM   #5
Rokcrln
Rokcrln's Avatar
I always use the one in the upper pic. I have never seen a rocker where teh bottom pic would even work. Normally they are so rusted out you need the extra lip just to getin back in place. I also build my own quite a bit because most of the time a small section of the floor is needed as well so I just bend my own up that includes juast a bit of the floor.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 04-06-2006, 03:06 PM   #6
70rs/ss
70rs/ss's Avatar
I just bought two new ones with the lip and they are tri-plus. I think the flat ones were a cheaper first run?
70rs/ss is offline   Reply With Quote
Old 04-06-2006, 04:43 PM   #7
meathead95
computer illiterate
meathead95's Avatar
i have never seen the flat ones either, where did you get them?
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 04-06-2006, 06:03 PM   #8
Solver
Solver's Avatar
The flat Inner rocker panels are from LMC truck in Lenexa ,KS
the Lipped Inner rockers are from Chevy Duty in Kansas City,MO now called Classic Parts of America
