Old 04-06-2006, 12:30 PM   #1
Huskerboy2
Windshield Glass is Cloudy - New Windshield?
Is there anything that can be done when a windshield, or any auto glass for that matter, gets that white, cloudy haze on it. My windshield has this along the bottom where it meets the gasket. I guess it's moisture that causes it. Is it time for a new windshield? Thanks.
'72 Chevy Blazer
Huskerboy2 is offline   Reply With Quote
Old 04-06-2006, 12:44 PM   #2
Re: Windshield Glass is Cloudy - New Windshield?
Nothing you can do, just the aging process. Replace it.
Old 04-06-2006, 01:10 PM   #3
70c10
67-72 Addict!
70c10's Avatar
The new one will make you feel like you had Lasik eye surgery!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-06-2006, 01:26 PM   #4
pat
pat's Avatar
This summer when I was working at the body shop on my cab we had just finished painting it and the owner asked if i wanted to take off the gloss on the top of the dashboard. He said that really glossy/reflective dashboards (like ours painted) would eventually cause windshields to get hazy like that.
Just a little FYI.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 04-06-2006, 01:31 PM   #5
carrzy4
Active Member
carrzy4's Avatar
Is it oxidized? Ive seen a polisher get it off, it was some commercial "Flitz" or something like that. Try something liek that or the mothers power ball.
http://www.flitz.com/
carrzy4 is offline   Reply With Quote
Old 04-06-2006, 01:58 PM   #6
smokekiki
Mike
smokekiki's Avatar
It is from the layers of glass separating and allowing moisture to seep in.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 04-06-2006, 09:50 PM   #7
68Stepbed
68Stepbed's Avatar
A freind of mine said he had a 69 once that did the same thing. He waited for a hot day and heated it with a heat gun to get the haze out. I haven't tried it yet. I'll try it this summer to see if it works. Mine is pretty bad.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-06-2006, 10:26 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it's not just moisture, but the layers actually seperating.
Has nothing to do with reflections from the dash either. From the factory, the top of the dash was flat paint, and every one of these trucks that I have seen with original glass was fogged to a point, and normally up top too.
Old 04-06-2006, 10:37 PM   #9
ChevyCrazy67
ChevyCrazy67's Avatar
I agree with longhorn, it's the sheets seperating, and from my experience once it starts the only way your gonna get rid of it is to get a new one.
Kevin
1967 C-10 swb fleetside
1968 C-10 stepside
1999 Z71- sons dd
1999 2wd silverado-my dd
2003 Tahoe- wifes dd
ChevyCrazy67 is offline   Reply With Quote
Old 04-06-2006, 10:49 PM   #10
Huskerboy2
Thanks guys. That's kind of what I thought. I had a '59 about 20 years ago that had some fogging on one of the side windows. Somebody told me back then that it's moisture in between the layers, as I recall. Sounds like a new windshield for the C30. 70c10, I'll bet you're right, it's going to look like a whole new world through that new windshield.
'72 Chevy Blazer
Old 04-07-2006, 04:44 AM   #11
Brad
Out of the carpool lane.
Brad's Avatar
The flat paint on a dash is so that you don't get reflections in your windshield from the dash.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 04-07-2006, 10:28 AM   #12
LONGHAIR
It is from the glass delaminating. There is nothing you can do but replace it and you should, not just from the visibility stand point but for saftey reasons too. The shatter strength of the glass depends upon this lamination. The plastic core is what retains the fragments when the glass breaks.
In most states there is a maximum measurement that is considered safe/legal in a commercial situation. It is part of the vehicle inspection process in the CDL test. I don't know if this applies to personal vehicles, but it sure can't be a bad thing........
LONGHAIR is offline   Reply With Quote
