04-06-2006, 07:50 PM | #1 | |
Son Of Gravel Man
Bench bleeding master cylinder
What would be the difference in bleeding the master cylinder before you install it as opposed to after? This would be before you hooked up any brake lines to it. After you bleed it you would hook up the brake lines and bleed it again normaly.
Daily driven 70 C10 longbed Its a work in progress Quote:
04-06-2006, 07:57 PM | #2 |
Re: Bench bleeding master cylinder
the way i bled mc is install them on the truck use the bleeder kit thats comes with it and slowy press the pedel and have some one watch till no more air then hook brake lines up bleed whole system but make sure not to run out of brake fuild or you'll be starting all over lol
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
04-06-2006, 07:58 PM | #3 |
the whole world....
if you bench bleed the master and reinstall the lines and pump up and bleed each fitting at the master you can get away from having to bleed the complete truck and save tons of brake fluid..and about 1 1/2 hours. and possiable broken bleeders on the wheel cyl's Last edited by rage'nrat638; 04-06-2006 at 07:59 PM. |
04-06-2006, 08:12 PM | #4 | ||
Son Of Gravel Man
04-06-2006, 09:09 PM | #5 | |
let us know what kind of a difference it makes..your pal mark |
04-06-2006, 09:14 PM | #6 | ||
Son Of Gravel Man
04-06-2006, 11:41 PM | #7 |
an hour and half??? wow i installed my mc bled it and bled the whole truck in 20 mins with a helper
04-07-2006, 01:53 AM | #8 |
I let them gravity bleed, an easy way to flush the system. then slowly pump them up and bleed at the caliper or wheel cylinder.
I have had proportioning valves stick on me when I haven't bench or gravity bled the mastercylinder Last edited by qksilver; 04-07-2006 at 01:54 AM. |
