Old 04-06-2006, 10:14 PM   #1
68 short step
picked out the wheels for the truck..but need help
here are the wheels im plan on getting,,,,, my question is what backspacing will fit on a stock stepside? also they will be 20 rear and 18 front.. and not sure on tire size but want about a 31 inch tire rear and 29 inch front. please help, the wheel and tire thread is cool, but the bs on most of them arnt mentioned
68 short step is offline   Reply With Quote
Old 04-06-2006, 10:16 PM   #2
68 short step
Re: picked out the wheels for the truck..but need help
o yea heres the pic
Old 04-06-2006, 10:16 PM   #3
68 short step
foose nitrous
Old 04-06-2006, 10:22 PM   #4
1LoC10
Insert Title Here
1LoC10's Avatar
Those are Billet Specialties Stiletto
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 04-06-2006, 10:26 PM   #5
1LoC10
Insert Title Here
1LoC10's Avatar
Damn, i just wentto double check on those.... and they $1,200 EACH! lol... you sure you want those
BOBBY
_69 SWB_
Old 04-06-2006, 10:37 PM   #6
redneckdds
redneckdds's Avatar
the torq thrust II's look similar and are about 3-500 depending on size
'67/70 Chevy C/10
'10 2500 Crewcab Duramax 4wd
redneckdds is offline   Reply With Quote
Old 04-06-2006, 10:38 PM   #7
Ain`t no wheel worth no $1,200 each!!None!That`s my story and I`m stickin`to it.
Old 04-06-2006, 10:40 PM   #8
matthufham
damn those are nice, but you'd be better off with some torque thrust style wheels, they're similar and cheaper. there's many like that.
matthufham is offline   Reply With Quote
Old 04-07-2006, 06:24 AM   #9
68 short step
errrrr...posted wrong pic.....ill post right pic when i get home...but the question is still the same......rim size on rear will either be 8.5 or 10 inches wide
Old 04-07-2006, 11:12 AM   #10
speedracer
Blank
speedracer's Avatar
rear tire with a 10" rim should be around 285 35 20 maybe a 285 30 20. front tire with a 8ish rim size would be around a 245 40 18 - 255 40 18. I would look at the specs on www.tirerack.com just type in the size choose a tire and look at the specs.
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi.
1977 Corvette 350-375hp 4speed, silver show car.
2002 S10 xtreme, work truck
2004.5 VW jetta GLI 1.8T 6speed, weekend warrior.
2013 Audi A3 TDI, the wife's car
speedracer is offline   Reply With Quote
Old 04-07-2006, 08:29 PM   #11
68 short step
pics of wheels
Old 04-07-2006, 09:31 PM   #12
SCOTI
SCOTI's Avatar
Rears could prob be 20x9.5 or 10 (whatever they offer) w/a 295-40 or 45. The 295-45 would be closer to your height requirement.
The fronts could go 18x8 or 8.5 (again, whatever they offer) w/a 255-45, 50, or 60. I'm pretty sure I've seen the 255-50 & that would be closest to your height requirement.
For front backspacing, I would go w/4.75 or 5". The 5" would be better for trying to keep the front track width even w/the rear. You'll need to trim the a-arm lip but that's pretty easy work.
For the rear, I can't say 100% because I've never played around w/a step-side to know just how tight clearances are..... especially if you've dropped it. My best guess (somewhat educated guess @ that) would say 20x9.5's w/4.5" backspacing. IIRC, the stepsides don't offer as much wheel well room vs. fleets. You could always mini-tub it on the cheap w/a set of fleetside tubs bolted in & trimming the bed-floor. That opens your choices up & I would then say 20x10's w/5" bs.
If you need help trying to measure all this out, I might be able to swing by @ some point in time.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
