Old 04-06-2006, 10:23 PM   #1
Blue85
Oilfield Trash
Blue85's Avatar
Best Way To Remove Rear Window?
What is the best way to take out the rear window and trim without wrecking it? I would like to save the window for sure and possibly the gasket if i can, I should also add that it is a factory slider.
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 04-06-2006, 10:31 PM   #2
ChevyCrazy67
ChevyCrazy67's Avatar
Re: Best Way To Remove Rear Window?
I took mine out with a couple of screw drivers. Start it on the inside close to one of the corners, usually you can start it with your fingers and work a screw driver in to the window frame then move down a few inches and slide the second driver in. Prying outward on it slighty as you go. If your gasket is old use a little wd40 to help it slide better. Also if you start at the top and work across usually you can ease it out without having to go all the way around with the drivers. I've done this several times and it's always worked well for me and was able to save glass and gasket.
Kevin
1967 C-10 swb fleetside
1968 C-10 stepside
1999 Z71- sons dd
1999 2wd silverado-my dd
2003 Tahoe- wifes dd
ChevyCrazy67 is offline   Reply With Quote
Old 04-06-2006, 10:45 PM   #3
Huskerboy2
Just my opinion, but save yourself some time and aggravation, go to the Truck Shop's website and order a new gasket for $22. Cut that old gasket around the inside as close to the glass as possible with a utility knife. You will only need to do maybe two or three sides, at the most. Then gently push the glass out. That old gasket isn't worth saving. You probably need a new one anyway.
'72 Chevy Blazer
Huskerboy2 is offline   Reply With Quote
Old 04-06-2006, 11:19 PM   #4
Sheverlay
Sheverlay's Avatar
My dad helped me replace a worn out slider with a solid back glass in my old F**d Ranger I had. I think he used a small rope, stuffed between the gasket to help pull it out. Dunno if it applies to these trucks or not.
Sheverlay is offline   Reply With Quote
Old 04-06-2006, 11:44 PM   #5
71chevytruckguy
71chevytruckguy's Avatar
don't pry it out!! me and my dad did that on my '71 with the orginal gasket, put dents all across the top of the cab. cut the old gasket out, it's a whole lot easier and new rubber is easier to work with the 30+ yr old dry, harder rubber. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 04-06-2006, 11:51 PM   #6
VinceY
Just need a couple more parts.
VinceY's Avatar
I had a glass guy replace a glass with the old original rubber. It was so dried out the guy actually cut himself on the rubber. Then it leaked, so I had to get another one anyway. Cut the rubber and get a new one. Roping in a window does work with our years.
1947 Studebaker M5 project to match the camping trailer.
1950 Chev 4x4 Pickup
1958 Shasta Airflyte Travel trailer (fresh restoration)
1971 C/10 Pickup(Frame off Restoration)
1972 K5 Blazer CST (Daily Driver & My Company Truck)
1976 Honda CB750 Bobber
1988 Jaguar XJ12
VinceY is offline   Reply With Quote
Old 04-07-2006, 12:30 AM   #7
Green Machine
Green Machine's Avatar
Yep, another vote for cut it, thats the best.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-07-2006, 01:38 AM   #8
qksilver
cut it out, if it was a hard to get gasket it would be different
qksilver is offline   Reply With Quote
Old 04-07-2006, 02:22 AM   #9
wibilly
wibilly's Avatar
i just poped one out of a junk cab yesterday with a screwdriver and a wood chisel dry in about 5 minutes but is much easier with a little lubracation. i like to use dishsoap rather than wd40. i try not to use wd40 anywhere near anything that may get painted in the next hundred years. i start in a top corner and work torwds center and down one side fror the inside pushing out but have also done it from the outside once when i locked my keys in
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 04-07-2006, 11:43 AM   #10
Blue85
Oilfield Trash
Blue85's Avatar
Thanks guys i'll probably just cut the rubber and get a new one.
87 Chev 3+3 4x4
Old 04-07-2006, 01:08 PM   #11
rigon4
rigon4's Avatar
I always just cut the rubber took 2 windshilds out and a back window out with a knife
rigon4 is offline   Reply With Quote
Old 04-07-2006, 04:17 PM   #12
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Ya, I tried the screwdriver thing on the 71 once. Had to buy a new windshield too. Good luck!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
