Old 04-06-2006, 10:44 PM   #1
62ChevyStep
62ChevyStep's Avatar
Question Advise on lowering
I have swapped out the torsion front for a 73-87 front spindle to spindle, I just ordered 2 1/2 inch Mcgaughy drop spindles, and 2 inch drop springs, and ordered 5 inch drop springs in the rear.
I have 20x8 1/2 with 275x40 front and 275x45 rear.
anybody have pictures with a 4/6 or close to it with 20's?
hoping this will all fit?
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 04-07-2006, 01:42 AM   #2
Slammed66
Needs a Big Block
Slammed66's Avatar
Re: Advise on lowering
WOW will that thing ever look better dropped.
this is when mine was 6/7
its now baggggged
are those back wheels gonna tuck? looks like they stick out a bit.
time to narrow the diff.
sorry I dont have my 20's yet , IM waitng to narrow the diff so I can fit 20x10's
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 04-09-2006, 04:17 PM   #3
62ChevyStep
should fit, there is some adjustment left to right as the PO I dont think perfectly centered the rear axle. we may have to roll the lip a little but other than that should be OK. I will let you all know, parts should be in midweek, hopefully next weekend it will be done. will post some pics
Old 04-10-2006, 03:32 PM   #4
cped
I am doing some research for a friend of mine with a '64. I have a '73-87 front x-member and suspension setup that he'd like to put in his '64. Any pointers, tips, tricks? Is it an easy swap? Any help would be greatly appreciated.
Thanks,
Chad
Chad
cped is offline   Reply With Quote
Old 04-10-2006, 06:34 PM   #5
Slammed66
Needs a Big Block
Slammed66's Avatar
yeah the 73 and newer front crossmember will bolt right in, you have to oblong 2 holes in the frame for the x member and you have to drill 2 new holes for the idler arm on the passanger side, If you dont feel like oblonging those 2 holes you can just swap control arms the will bolt right on 2 upper stud and 2 lower ubolts 6 nuts total each side.DONE.
1964 Short box
1972 K10
Old 04-10-2006, 06:43 PM   #6
62ChevyStep
Couldn't have put it better if I tried
Old 05-15-2006, 09:33 PM   #7
gotmud
gotmud's Avatar
Question Re: Advise on lowering
Ive got the same setup....64c10 with a 73+ front cross member. To lower it what are the pros \ cons of doing just shorter springs or just drop spindles vs both????
Glenn
Cumming, Ga
(68 C/10 Fleetside LWB 307
(64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty)
(2001 Porsche Boxster S - 168 MPH of fun)
(2005 Chevy Avalanche Z71 1500)
gotmud is offline   Reply With Quote
Old 05-15-2006, 09:38 PM   #8
Slammed66
Needs a Big Block
Slammed66's Avatar
well to me , they both lower it 3 inches
if you do 1 or the other it makes the truck sit where it should factory if you did both it would look good!
81 crossmember 3 inch springs and 3 inchs spindles
1964 Short box
1972 K10
Old 05-16-2006, 01:11 PM   #9
SIR
SIR
SIR's Avatar
...4/4 drop...remember it will settle...and drop as much as 1/2 "..and scraping parking lot stops in no fun.....
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 06-24-2007, 06:16 AM   #10
63 & 64 Bowties
and a few others
hey, how 'bout some quick advice for a newbie? a 63 c-10 with stock front suspension. I have Chevelle springs in rear, seems to have dropped it about 3 inches. I'm gonna cut the front springs, I think one coil cut will drop it about 2 inches, but here's my question, cutting the front springs, will I have to have it aligned? what happens to caster/camber?
63 & 64 Bowties is offline   Reply With Quote
Old 06-24-2007, 11:07 AM   #11
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
You should cut a coil and a half off...That would be perfect. Throughout the years of lowering vehicles, I have found that 1 1/2 turns has been kind of a 'rule-of-thimb' for a moderate drop. The reason for this is the last coil is shaped to rest flat on the next turn, so cutting the first, and then half of the next will be right on.
The caster/camber will be affected slightly.
John
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 07-12-2009, 11:39 PM   #12
daverod
SSN 706
daverod's Avatar
John
Chief Does it matter from which end you cut the coils off. Do you have to remove the arm/spring to do this?
daverod is offline   Reply With Quote
Old 07-12-2009, 11:48 PM   #13
joe231
joe231's Avatar
yes you need to remove the springs, and I would strongly advise you to cut off the bottom, the top of the spring has a smaller coil that locates the spring in the upper pocket...
Our '66 has a mid 80's front cross member, I cut one coil and 3 inched of the next coil off, I didn't do a before and after measurement, but I guess-timate the drop the be around 2.5 inches. Had jeep coils on the rear and it gave me a nice, but not too much, rake.
CHEVY ONLY
Old 07-13-2009, 09:07 AM   #14
daverod
SSN 706
daverod's Avatar
Thanks Joe I'll add that to my list of things to do.
Old 07-13-2009, 10:20 AM   #15
joe231
joe231's Avatar
CHEVY ONLY
Old 07-26-2009, 09:41 PM   #16
jess66chevy
jess66chevy's Avatar
Here is my truck with 20's. The tires were 285/50/20. They didnt rub in the front or the rear. Since then I put 255/45/20. I lowered it 5/7.
jess66chevy is offline   Reply With Quote
