Old 04-06-2006, 11:17 PM   #1
KEH
Better late than never
KEH's Avatar
Towed home - clutch problem
I went to shift and the clutch would not disengage the trans. I felt grinding in the pedal and had to kill the motor before coming to a stop when I couldn't get it out of gear.
Removed the bottom cover and had the wife work the pedal and the throwout bearing is working fine. However, the disc stays against the flywheel no matter how I adjust the linkage. There is only 30k miles on the setup, but I guess maybe the pressure plate gave out? Looks like I will be pulling it apart this weekend. Any ideas?
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 04-06-2006, 11:38 PM   #2
GMCMAX
Active Member
GMCMAX's Avatar
Re: Towed home - clutch problem
I've had a piece of the lining come loose before and get between the flywheel and the rest of the lining, the extra thickness wouldn't let it disengage enough; also had a spring break on a three finger pressure plate and wedge inside, it wouldn't let the plate pull away from the disc on that side...
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 04-07-2006, 12:29 AM   #3
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Hate to say it but looks like it's time to change the pressure plate
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 04-07-2006, 12:46 AM   #4
Green Machine
Green Machine's Avatar
Check Northern Auto Parts, I just got a new Pioneer set for 87 bucks , disk, plate, bearing and bushing plus tool, looks OK to me.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-11-2006, 10:24 PM   #5
KEH
KEH's Avatar
Fixed the clutch over the weekend. Here was the problem:
Old 04-11-2006, 10:40 PM   #6
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Glad you got her fixed. I hate it when you never know what happened. Later, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
