Old 04-07-2006, 12:20 AM   #1
redneckdds
redneckdds's Avatar
gotta pick an engine... need help!
350HO deluxe or the "keyturn" crate??? will the GM compressor work or the keyturn setup interfere with a Vintage air system? the keyturn comes with extra stuff I will need. anyone have any ideas on this?
'67/70 Chevy C/10
'10 2500 Crewcab Duramax 4wd
redneckdds is offline   Reply With Quote
Old 04-07-2006, 10:42 AM   #2
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
Re: gotta pick an engine... need help!
I would get the engine as assembled as possible, and avoid the cost and time of putting the rest of it together yourself. I'm not familiar with the GM compressor set up, but the Vitage air system will bolt up to any GM accessory threaded head.
If there are features you don't like on the turn-key version, do some math to find out how much more it will cost to change things out. Valve covers, distributor, etc.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 04-07-2006, 11:33 AM   #3
bskylerj
bskylerj's Avatar
Is the 350 rebuilt and assembled? Would you be doing it? The crate motors are nice. As you mentioned it is turn key.
P.S. have you thought about a big block?? lol
bskylerj is offline   Reply With Quote
Old 04-07-2006, 11:42 AM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
What are the prices? I called about a GM performance crate 350 last year and the price was around $1600 and it included everything but the intake (excluding all the front pullys, accessories, etc...)
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-07-2006, 12:27 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Seems like I have seen Goodwrench 350's for less than $1400. Shipping is extra, of course. Check with your local GM dealer.
In Scoggins-Dickeys' catalog, a GM Reman 350 costs more, and has less warranty, than a NEW Goodwrench 350. So, be careful of what you order. Jasper has a 3-yr/75,000 mile warranty on their rebuilds, so you may want to check them out, too.
In the end, cubic inches always wins, but that's another story.
Member Nr. 2770
Old 04-07-2006, 01:22 PM   #6
redneckdds
redneckdds's Avatar
its called 350HO Deluxe and it is a new crate engine... its the 330 hp long block for about $3500 1yr warranty...
http://www.crateenginedepot.com/stor...968-P5C53.aspx
the turnkey is about $4300, same motor just with everything else, so I dont have to buy and install all the accessories.
http://www.crateenginedepot.com/stor...-P1427C53.aspx
I was told the water pump is installed backwards on the turnkey due to yada yada yada... just worried about the Vintage air working without any problems...
'67/70 Chevy C/10
Old 04-07-2006, 01:51 PM   #7
JMac11
JMac11's Avatar
Check Evil Bay... Place in Pheonix keeps a base 330hp for 1999 buy it now and 99 freight.......
JMac11 is offline   Reply With Quote
Old 04-07-2006, 07:43 PM   #8
dougs69c10
dougs69c10's Avatar
fyi, At work napa, we have many new performance crate motors, a really nice one is a 350 no water pump, carb or dizzy, 300 hp 400 ft lbs, dyno tested, proven, run live, for 2500 and no core. We have others that range from 2500 to 4500 and hp ratings from 300 to 450 out of a 350.
The best news on the first one for 2500 bucks, it runs on 87 octaine
1969 c10 stepside 250 inline six, 4speed granny tranny, 4.11 posi rear end
dougs69c10 is offline   Reply With Quote
Old 04-07-2006, 08:36 PM   #9
redneckdds
redneckdds's Avatar
thanks guys for the heads-up on the other options... I was actually considering saving a few thousand $$ on ebay, but am not sure if I will end up buying from gm in the long run... can these motors from the dotcomers be trusted?
'67/70 Chevy C/10
Old 04-07-2006, 08:42 PM   #10
JAKES 68GMC
Aluminum slot wheels rule...
Be different. Get a big-block GMC V6.
JAKES 68GMC is offline   Reply With Quote
Old 04-07-2006, 09:22 PM   #11
TP from Cntl PA
TP from Cntl PA's Avatar
It would run as good as the other two if your actually using the truck for work IMO
I could get up on my soap box and rattle my mouth off about what I'd put in it, but I've notice their isn't much of a fan club here for engines with other than a 8 cylinder gasser in a V-type arrangement.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 04-07-2006, 10:15 PM   #12
68Stepbed
68Stepbed's Avatar
I would just go with the deluxe engine, then buy a bracket system Alan Grove. You can buy hoses and what not to work with the GM accessory system. Classic Trucks did an article with an aftermarket A/C system with the same accessory system in a 68 about a year ago.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
