04-07-2006, 09:57 AM | #1 |
Wrong ball joints?
I bought new lowering spindles for my 72 from GMCPAUL'S and was installing them last night. I put in new upper and lower ball joints while I was doing the job. I had the spindle in place,and was torquing down the upper ball joint but can't get it tight enough to see the hole for the cotter pin to go through. I can't get it tightened down enough it seems.The I looked at the other new one I have for the other side and its identical. I put the rest of it together and went to the other side,same thing on the other side too.
Anybody run into this problem? I called the parts place and they verified that they gave me the correct ones. Any thoughts,ideas would be appreciated. Thanks, Andy |
04-07-2006, 11:46 AM | #2 |
Re: Wrong ball joints?
Try the old spindle on the new ball joint. You may have the wrong year new spindles.
69 swb stepside, rebuild and upgrade in progress |
04-07-2006, 04:28 PM | #3 |
some spindles are for 73 & up trucks and require ball joints from these years. Mine did but I can't remember if it was the bottom or the top joint.
72 CHEYENNE 10 SUPER 468/400/3.73 |
04-07-2006, 05:16 PM | #4 |
I believe the correct upper for a 71-72 spindle is a Moog K6124. Lower is K6117,
