Old 04-07-2006, 09:59 AM   #1
phlegm
Still Green but learning
phlegm's Avatar
Exhaust manifold leak (issue)
I hear a strange noise from the engine that a few of my shade trees and I at church have decided is a leak at the exhaust manifold. Before I tear it down I want to make sure there is not something easy that could be causing this that can be fixed without removing them.
From what I understand there is a thermostat type device that constricts the flow out of the exhaust in order to warm the engine up faster, and these devices are on both sides and can leak from the seals after a while.
Is this true? and should I check this first. any other obvious things to check? Just want to get as much Background as I can before I start digging in. Thanks in advance.
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 04-07-2006, 11:44 AM   #2
jerry moss
Born Psycho
jerry moss's Avatar
Re: Exhaust manifold leak (issue)
you should not have two heat risers, only one is normal. i work in a muffler shop and we also sell a block that replaces the heatriser. a lot of people make a mistake when they work on the exhaust manifolds and use gaskets between the manifold and the head, a guarnteed leak sooner or later. have the manifolds surfaced, clean the heads real good and bolt them up metal to metal, torque the bolts correctly for proper expansion and contraction and you'll not have anymore problems. if the studs at the flange end are iffy, nows the time to replace them too. if you have old style manifolds with the choke heat tube inside, those can burn through and create a leak also, if thats the case, you can have the choke tube holes welded closed before resurfacing. hope this helps.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 04-09-2006, 10:20 PM   #3
phlegm
phlegm's Avatar
How hard are these to replace?
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 04-09-2006, 11:25 PM   #4
jerry moss
Born Psycho
jerry moss's Avatar
the only difficult part is the studs, depending on the amount of corrision. usually a little heat from a victor wrench will help.
jerry moss
