Old 04-07-2006, 12:28 PM   #1
Zonaman
Zonaman's Avatar
Question Hard to shift when cold
The column shift handle is really hard to pull toward you when the mornings are chilly. Seems to "soften up" after driven for a while or the weather is warm. What's doing this? How can I remedy that?
Thank you!
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 04-07-2006, 02:15 PM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Hard to shift when cold
Wd-40 everything that moves.LOL The shift rod rotates as well as slides up and down,and the linkage at the bottom of the column gets dry and gummy causing it to drag and become stiff.
sneakysnake is offline   Reply With Quote
Old 04-07-2006, 03:49 PM   #3
Lemield
Lemield's Avatar
Zonaman,
I had a very similar problem on my C20. Mine was really hard to pull back and move into gear...much easier when it was warm outside. I recently replaced the original steering wheel and noticed that the plastic on the back of the hub was coming loose. Replaced wheel with a newer one and no more hard to move lever. Coincidence? Just my 2cents worth.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 04-07-2006, 03:51 PM   #4
67chevemall
67chevemall's Avatar
yep a whole can of Wd40 will clean it and make move better....
67chevemall is offline   Reply With Quote
Old 04-07-2006, 04:26 PM   #5
cdowns
cdowns's Avatar
it doesn't hurt for every million miles or 35years to flush and change the tranny grease
Old 04-07-2006, 05:48 PM   #6
jamie72
jamie72's Avatar
had one do this i broke the end of the shifter off, so be careful, it in the coulm it gets dry and dirty, i would just take the shifter out and spray wd40 in the shifter hole and work it in a little, good luck
jamie
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 04-07-2006, 11:43 PM   #7
atcavage
I have the same problem, but only when the weather is hot. Which is why I don't like running errands in my truck because once it heats up, things start sticking. I'm almost ready to convert to an automatic because as much as I love my truck, I hate fighting the shifter.
1972 1/2 ton Chevy C10 V-8 350, crate engine, with Flomaster dual exhaust. She's Old Blue the Truckinator (no relation to Arnold )
atcavage is offline   Reply With Quote
Old 04-08-2006, 01:01 AM   #8
kiriuskris
New Member
kiriuskris's Avatar
I had the same problem with my 67. It would just lock in a gear and would not move unless you pulled on the shifter real hard. I think someone tried that when they drove it and ended up breaking the lever on the transmission for 1/R. I would get around it with just going under the hood and jiggling the linkage on the column. Once I get the replacement lever I am going to soak it with WD-40 and spray some chain lube in there.
Kris
I'm about hot cars and fast women. Or was it hot women and fast cars?
kiriuskris is offline   Reply With Quote
Old 04-08-2006, 08:47 AM   #9
Lemield
Lemield's Avatar
OK...I guess I am the only dummy here who thought he was asking about an automatic.... Boy an I dummmmm.
Larry
Old 04-08-2006, 10:51 AM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
No, you're not the only one -- I got halfway through before it occurred to me it might be a stick... My auto does the same thing in cold weather when it needs a shot of WD-40. In fact, check his siggy... he has a 700r4!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 04-12-2006, 02:28 PM   #11
53burb
53burb's Avatar
On the manual trannys that I have had in the past, they are hard to shift in the morning, even in Phoenix it gets cold (to me anyways). As the vehicle and tranny oil warmed up, it moved easier. I believed it was caused by the tranny oil being cold and thick, as it warmed up, it became thinner.
53burb is offline   Reply With Quote
Old 04-13-2006, 08:37 PM   #12
Zonaman
Zonaman's Avatar
The WD-40 trick worked. Was chilly this morning and (my automatic) shifted fine. Thanks! Hope things work out for all you manual tranny guys!
Old 04-14-2006, 10:49 AM   #13
Lemield
Lemield's Avatar
Guess I'm not so dummmmmm after all.
Larry
