04-07-2006, 06:13 PM | #1 |
Ground Straps
I just got some new ground straps. I have only seen two on my truck and the package came with five! Does anyone have a drawing or know where they all go. Thanks
1973 gmc swb |
04-07-2006, 10:45 PM | #2 |
Questionable
Re: Ground Straps
I can tell you that one goes from the frame by the pass. side front cab mount to the underside of the cab.
i need to know this stuff too though. I need to replace mine as well.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
04-07-2006, 11:37 PM | #3 |
Re: Ground Straps
Thats a start four more to go
1973 gmc swb |
04-08-2006, 12:02 AM | #4 |
Re: Ground Straps
1 from passenger side front frame horn to inner fender near front edge as it dips down towards frame, 1ea from passenger & drivers side valve cover to firewall, 1 from passenger side cab frame mounting bracket to front cab support above it, 1 from 2nd from rear LWB or far rear crossmember SWB to frame.
GMCPaul |
04-08-2006, 11:05 AM | #5 |
8 vehicles only 4 that run
Re: Ground Straps
Go Paul, Go Paul! It's your birthday! You're the man!
95 2500 350 w/ 3.73 72 GMC 1500 SWB stepside 65 Chevy C10 SWB stepside 72 Chevy C10 LWB fleetside |
04-08-2006, 01:31 PM | #6 |
Re: Ground Straps
Damn, leave it up to Paul to leave us in the dust....
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
04-08-2006, 02:49 PM | #7 |
Questionable
Re: Ground Straps
funny, his site is the first place i looked for the info b/c i knew he'd know it
04-11-2006, 02:30 PM | #8 |
Re: Ground Straps
Well I was wrong. I only found one ground strap on my truck. The one I found was cab support to the frame on the passenger side. I was looking on the fire wall for holes for the ground straps and there are none. So do I need them still. The truck is running but when I turn on the head lights the radio shorts out for a second then comes back on.....
1973 gmc swb |
04-26-2006, 12:02 AM | #9 |
Questionable
Re: Ground Straps
next question: do any of the board vendors sell a ground strap kit with all the replacement straps?
04-26-2006, 12:44 AM | #10 |
Re: Ground Straps
