Old 04-07-2006, 10:49 PM   #1
rodstored-72
chevy truck fan
rodstored-72's Avatar
Radiator Hose Type ????
hey guys,
well i finally got the radi core support bolted up to the truck with the flex-a-lite fans . now i am trying to find a upper radi. hose for my truck. it is a 72 chevy 2wd with a 350 sbc, i have a '90 model p/u serpentine belt setup. the original upper hose hits the alt. now. so i was wonder if any of you guys who have done the same belt setup could tell me what hose you used for your truck??? i am sure there is a stock hose that should work since the setup is basically stock as well. i tried a stock hose from a '90 model & i could "make" it work, but the end at the radi. side is too small!! if anyone could give me their solution, or an idea then i would very much appreciate it....
thanks for all the help!!!
rodstored-72
rodstored-72 is offline   Reply With Quote
Old 04-08-2006, 12:32 AM   #2
Chevy4Life
Chevy4Life's Avatar
Re: Radiator Hose Type ????
I just put a '92 3/4 ton serpentine setup on my '67. I used both hoses from the '92 truck and they fit perfect. I don't like how high the top hose sits and I'll probably try to find a better one when I switch to electric fans. The '92 hose may have had some swell to it but I don't remember fighting it at all.
Chevy4Life is offline   Reply With Quote
