04-07-2006, 11:24 PM | #1 |
steering coupler converting to "new" steering box
I am trying to convert to the newer "quick ratio" steering box. I bought a reman at the auto store it appears as though my coupler is too large to fit on (or tighten) on the front shaft? did others have this problem when using the new box? I believe the year i got was a 76 this is 3 1/4 turns lock to lock ( I confirmed) and has the standard threads so it should be an easy conversion but this coupler problem
please help... Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
04-08-2006, 12:02 AM | #2 |
Re: steering coupler converting to "new" steering box
Are you having a problem installing the steering shaft coupler on the steering box. If this is you problem, the 77 to 86 model steering boxes have a 3/4" shaft, the 68 to 76 has a 13/16" shaft. When I replaced the box on my 69 I found my shaft would not go on. I found that my truck had the 77 to 86 box on it and I ordered a 69 box. I could have changed the rag joint out to a 69 on the box side, but I returned the 69 box and got the later model to solve my problem.
1977 THRU 86 Model, ¾” shaft (68-76 has a 13/16” shaft) |
04-08-2006, 08:14 AM | #3 |
glenn thanks I will check that out. I thought I asked for a 76 but don't remember...
I am trying to change to the later model one for the "quicker" steering I will do some checking dave
04-10-2006, 08:03 PM | #4 |
Just buy the rag joint to fit your new "quick box". You will then be able to use your existing intermediate shaft to complete the change over.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
04-10-2006, 09:39 PM | #5 |
It's a good idea any way to get a new one. Safety and it won't vibrate
04-11-2006, 09:10 AM | #6 |
Thanks guys I am going to pick one up today. I removed the old steering box and have the new one ready to install.
Dave
07-05-2011, 09:36 PM | #7 |
old but useful thread. Another question...do you recall how the diameter is measured on the splined shaft or the splined coupling? For example, should the shaft OD be measured on the outside of the splines or in the bottom of the grooves or some third option?
Thanks. Mark
Mark 57 Austin Healey 3000 (sold many moons ago, unfortunately) 67 C10 (in progress, son's) w/ 1993 350 SBC, '96 Vortec heads (custom polished ports), EPS Performer intake, Holley carb, cam, MSD ignition 93 C4 Corvette (mostly done, son's) |
