Old 04-08-2006, 12:10 AM   #1
jc
jc's Avatar
help, dome light ground problem
need i little help trouble shooting this
heres were im at so far
i have power to the dome light
bulb didnt light
so i grounded it to the cab and it goes on and stays on
no matter what position the headlight switch is in .
this is 67 lwb pu it does not have dome light switches in the door jambs
heres the only thing i can think of-bad headlight switch .
does this sound right to you guys
also are the cluster bulbs available at an auotzone,pepboys or napa
any body know the bulb # i dont thik its the same # as the orginal but i could be wrong
thanks in advance for any insight , JOHN
2004 Silverado 2500HD Crewcab 4x4
2000 TOYOTA 4RUNNER
1971 CHEYENNE LWB (THE LOVE SHACK)
1967 c-10 lwb (THE FARMERS DAUGHTER)
jc is offline   Reply With Quote
Old 04-08-2006, 12:13 AM   #2
rage'nrat638
rage'nrat638's Avatar
Re: help, dome light ground problem
i thought these had power all the time and the ground is what is switched...
someone correct me if i am wrong
dash bulbs are 194's you can get'em any where
rage'nrat638 is offline   Reply With Quote
Old 04-08-2006, 12:19 AM   #3
jc
jc's Avatar
yes it does have power all the time
but only lights up if i ground it to the cab
2000 TOYOTA 4RUNNER
Old 04-08-2006, 01:04 AM   #4
GMCMAX
Active Member
GMCMAX's Avatar
On mine, the wire under the sill plate had a nick in the coating and rotted the wire out inside. Spliced in a new piece and was fine. This is a ground that goes back to the h/l switch.
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 04-08-2006, 05:17 AM   #5
jhow66
jhow66's Avatar
The dome light has two wires leading to it-orange (hot wire)-white (ground wire). The white wire is hooked to the light switch . When you turn the switch to the left it grounds the wire. The white wire is probably broke between switch and dome light.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-08-2006, 05:31 AM   #6
jc
jc's Avatar
i think i have a brand new dome light and wire haress some ware and i know i have a spare switch
i will just swap some parts and see if itll work
im just starting to notice the little things with this truck as im being forced to drive it daily to work untill .
my 97 blew an intake gasket when i got home from work friday morning
so i will be driving the 67 till i have time to do the intake
and while i am so board at work i went out and tinkered with the farmers daughter (thats her name)
i never have time for her when were home.
after only 100- 200 miles on her in just a little under a year
shes now getting 66 miles aday on her
sunday night its time to strech the legs on the 71 for the first time scince fall
if weather permits (this ones not aloud to play in the rain)
come monday its time to do an intake oun the 97
2000 TOYOTA 4RUNNER
Old 04-08-2006, 07:25 PM   #7
jc
jc's Avatar
the problem was in the harness ,
i dont see the break but theres one the some were
installed a new dome light kit today and it works
it kinda hurt my pride to put the after market light in
i guess i cant say my truck is all original parts anymore
2000 TOYOTA 4RUNNER
