Old 04-08-2006, 12:31 AM   #1
Mechdawg
Mechdawg's Avatar
6 lug stock rotors
Im about to get a set of stock 72 C-10 disc brake spindles for my 67 but Id like to keep my 6 lug set up. All the local parts stores seem to only show a 5 lug available. Is there a different year I should be looking for to get 6 lug rotors for my truck? Thanks all
Mechdawg is offline   Reply With Quote
Old 04-08-2006, 06:57 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 6 lug stock rotors
No, the 6 lug rotors are special rotors that the aftermarket companies have made up special. You have to pay the bucks and buy them from a vendor.
Old 04-08-2006, 07:31 AM   #3
70GMCer
70GMCer's Avatar
From what I have read on here, and what some have done, is use 88-98 3/4 Ton 2X4 light duty rotors. They are 6 lug and you will have to change the lugs. They are metric. They're available at Autozone.
http://67-72chevytrucks.com/vboard/s...ad.php?t=35042
This should answer your questions.....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-08-2006, 11:08 AM   #4
lilred67
lilred67's Avatar
i bought six lug rotors for my'67 from early classic enterprises(www.earlyclassic.com). they are new,not redrilled 5 lug rotors.all you need to do is install new bearings for a '72.
lilred67 is offline   Reply With Quote
Old 04-08-2006, 11:11 AM   #5
c10crazy
Like a Rock!
c10crazy's Avatar
lilred67, are they installed yet? any probs?
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 04-08-2006, 07:45 PM   #6
lilred67
lilred67's Avatar
yes, they have about 7,000 miles on them.no problems,i highly recommend them.
Old 04-09-2006, 10:07 AM   #7
c10crazy
Like a Rock!
c10crazy's Avatar
Cool, what other front end parts or swaps did you have to use to get disc brakes on your 67?
69 LWB
Old 04-09-2006, 11:42 AM   #8
Geezer
Geezer's Avatar
I used the entire cross member and steering from an 88 sub. I thought I could use the 91 6 lug rotors but the centerline of the rotor is ½ “ off to the outside and the calipers won’t fit. Now I need to find out if the aftermarket rotors from classic enterprises and such will fit the 88 sub spindles or if I’m going to have to change spindles. Now I’m wondering if the 91 spindles will fit?? If I get it figured out I’ll post the results…
If you can't drive it park it! If you can't park it milk it!
Geezer is offline   Reply With Quote
Old 04-09-2006, 09:02 PM   #9
lilred67
lilred67's Avatar
i used upper a-frames, spindles,and all the steering linkage from a '72.had to replace lower ball joints to the '72 style.
