door lock problem...
hey, just thought i would see if anyone knew what the deal was... the drivers side door on my wires 87 GMC sometimes wont unlock.. from the outside with key or from inside by pulling on the door lock (manual locks). I can pull on the handle on the inside and try pulling the lock again and it usually works, though sometimes it has taken upto 10 times to finally get it. From the outside you have to push the button then turn the key... any ideas before i tear into it?
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
Re: door lock problem...
Can't really help you, but i have the same problem sometimes.
If I lock the door while inside, sometimes I will have to unroll the window and push the button outside to pull the lock up. And unlocking with the key I may have to push the button first, or else the key wont turn. Power locks by the way. I haven't tried anything yet, but I think when I try I am gonna spray down the latch and any other linkage in the door. Good luck. Post if you find anything. -Jeremy
79 Jimmy slammed AKA James Down |
well i have figured out a bit more about this... it only jams up on me when i try to open the door before unlocking it, and to get it to undo i just push the outside button.. weird.. havent had time to tear into it further.
Right turn Clyde
I have the same problem from time to time. I dunno why it does it but it acts just like what has been said here.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
![]() Join Date: Apr 2005
Yep my 84 GMC does the same thing most of the time on the drivers side. I believe it's just wear and tare over the years.
![]() Join Date: Dec 2003
lube all the joints of the mechanism in the door and it will reduce the issue. But just lick Slop said, its just wear and tear.
