Professional Grade
67-72 Chevy accessory bracketry pics needed!
Hey guys!
I'm wanting to convert my truck from Serpentine back to V-belts. But, I need to move my alternator over to the driver's side of the truck, and I need the bracket to bolt only to the engine's heads / water pump etc, and not to the intake manifold in any way. I think that 67-72 brackets fit the bill, so I'd like to see a few pictures of your guy's belt setups, and if it'll work like I hope it will, I'll go and find a 67-72 donor vehicle for brackets ![]()
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Re: 67-72 Chevy accessory bracketry pics needed!
Here you go!
Jim |
![]() Join Date: Feb 2004
man that looks pretty
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
Professional Grade
Looks exactly like what I need!
Anyone have anything closer up? I need to see how it all bolts together ![]()
Professional Grade
TTT -- The more pics the better!
Lets see your shiny new engines, and your old greaseballs ![]()
Post Whore
![]() Join Date: Feb 2000
Here is a pic of the alternator bracket and power steering bracket on my 70 K5, however, this is not the correct motor, it is a 400sb and the heads were drilled to accept the alternator bracket (the heads turned out to be early 60's 327 heads - I do think this is the correct brackets though.
![]() Here is another shot of the alternator bracket. ![]() Here is the alternator bracket that was on my 69's 307. ![]() And here is a pic of the power steering bracket on the Blazer's 400sb - it attaches to an engine mount bolt and on the front of the block there are two bolts. ![]()
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 04-10-2006 at 11:59 AM. |
Active Member
are you interested in selling your serpentine setup??
Professional Grade
For those who are PMing me -- I've got a setup from a Camaro on my truck now
![]() Thanks anyways!
Check this thread, he has the brackets that you need.
http://67-72chevytrucks.com/vboard/s...d.php?t=203995 |
